SOURCE: need onan marquis 5000 model 5bgmfa26105f wiring
Give me to full model and spec # and I will email you a service manual.
SOURCE: Just purchased 1985 pace motor
Hi, the deep cycle battery is for the home part and should charge through the external connector port. The regular battery is for the engine. Is the regular battery charged up too?
Testimonial: "Thanks that was good infromation no I haven't charged 1 year battery ill replace it thanks again."
SOURCE: I have a 6.5k Onan
is this unit under a load,onan generators have a self regulator to drop the rpms down when not under load
SOURCE: how should a 12 volt deep cycle battery last when trolling on #1 with a 30 lb thrust
It depends on the Amp/Hour rating of the battery and the amount of current your motor draws on setting 1.
SOURCE: The Marine deep cycle Battery
If you value your other componets in you setup throw away that unit ASAP. They are nothing but problems and I'm sure that's where your issue lies. Even if you replace the blown fuse (known issue with this unit) your gonna have other problems down the line. Also stay away from the Sunforce 11260. I like Sunforce products but for some reason these two particular models are just complete junk,
The Onan Marquis is not designed to charge your batteries. There is no charging system on most RV gensets. They are designed to work with the coaches inverter to charge your house batteries.
As for some of the other answers on here.....
Onan does not have a variable speed RV genset with the exception of the inverter diesel units the built for about two years arounf 2006. They were discontinued because they were junk. The house batteries on all coaches are supposed to charge off of the units inverter wether connected to the land line or the genset. The coach starting battery is charged off the enf=gine alternator on the coach motor.
