Question about Car Audio & Video
Amp shuts off when trying to play cd
I hooked up an amp for 2 subs in the back from my Alpine CDA-9827 head unit. It works when you play the tuner but it shuts off when you go to play a cd. There must be some setting where you can switch it so the amp works when playing a cd. Anyone know??
  • Matt Stacey
    Matt Stacey Jul 29, 2009
    Ur right! I switched it over and it works great! Thanks!!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
It sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
Posted on Jul 29, 2009
My alpine cda9885 plays my subs when the tuner setting is on but nothing else, The amp turns off when I switch between the settings and doesn't turn on until on the tuner.
sounds like you have the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) turning the amp on. the antenna remote turns off when the radio is switched to cd mode.
Sep 08, 2010 | Alpine CDA-9885 CD Player
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
