Question about GE 25952EE1 Cordless Phone
The display has gradually disappeard on all three handsets
The letters and numbers on the display began to break up after several months then some but not all disappeared now I see only the occasional black dot on the display
Battery no load voltage seemed Ok and changing batteries did not help
Hope your experts can come up with a solution other than buy from a different manufacturer
Jack from Toronto
That is an celphone? if celphone i think the problem is the LCD screen have the problem you can go to the service area and ansk to replace other LCD of your celphone that is the best way to do. you can not solve that even you change your battery or anything...
Posted on Jul 29, 2009
How do I reset my date & time for Panasonic kxtga470
The KX-TGA470 handset works with several models of Panasonic cordless phone base units. Press Menu and then press #. Next press 1 0 1 . (Alternatively use the arrow keys to navigate to find Initial Settings and then Set date and time after pressing Menu.) If you need to change the date, type in the date as three sets of two digit numbers (month, day and year). Then press OK. Next type in the time. Press OK and then select AM/PM with the arrow keys if you are using 12-hour time. Finally chose Save followed by Off.
The manual for the base describes setting the date and time. See http://panasonic.ca/viewing/ALL/KX-TG4711C/OI/TG4711C_PNQX5094ZA/TG4711C_PNQX5094ZA.pdf on page 15.
I hope this helps.
Nov 03, 2014 | Lands Phones
Marantx SR4600 Receiver
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
Sep 07, 2007 | Marantz SR4600
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
Which number is the serial number on the washer the short one with numbers and letters or the longer one with just numbers this is an LG WM2101H washer
serial number would be three numbers, followed by at least the letters KW, then possibly two more letters and several more numbers.
Mar 23, 2011 | LG WM2101HW 4.0 cu.ft. Washer
"out of range"
I have a GE DECT 6.0 Digital phone (silver, 2-handset model) and one of the handsets began displaying "Out of Range" and was unresponsive. We've had severe lightning around here in recent days which interfered with the digital tv reception, so I'm pretty sure that's what caused the problem. Here was what worked for me:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
This action re-initiates the transmission between the base unit and the handset.
Jul 13, 2009 | Thomson GE 27907GE1 Cordless Phone
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
No Caller display
I have had Several problems with the Freestyle 2200 phones.
The best solution I have found is to remove the rechargeable batereis for 30 seconds and then replace them. This seems to work every time.
Jan 21, 2008 | British Telecom Freestyle 2200 Trio...
Display
Is this on the both hand sets? If it is then the only thing common to the both of them is the base and that would be your problem. If it is not then you will have to change the handset that is fading. It is not worth it to repair the handset
Aug 16, 2007 | GE 21028GE3 Cordless Phone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
GE 25952EE1 Cordless Phone Logo
314 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
