Question about Whirlpool WGD5300S Dryer
Is it possible to change the dryer door that will open from right to left instead from left to right
    Scholar:
  • 117 Answers
Yes ,most dryers will allow this. although you will have to remove door to do it. You should see mount holes on the other side of door sometimes have plugs to remove or srews. The hinges on the door will have to be moved to opposite side. Once again should see mount holes. The whole operation takes a matter of minutes once you see how it is done. Hope this helps
Posted on Jul 29, 2009
Can the dryer door be reversed to open the opposite way on the 800 series Bosch?
it is possible . I suggest that you talk to a service repair shop to get details of how to to it if it can be done.
Feb 06, 2013 | Bosch Nexxt 800 Dryer
Can I change the door to open left to right instead of right to left
yes,Tim:
http://www.ehow.com/search.html?q=reverse+dryer+door
May 29, 2011 | Kenmore HE5 Electric Dryer
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
How do you move the dryer door so that it opens form the left instead of the right
http://www.ehow.com/how_5968181_change-dryer-door-left-right.html
Oct 24, 2010 | Dryers
Looking to change right hand open door to left hand?
It is not possible to switch the washer door directions, but is is possible with the dryer door.
Jun 12, 2010 | Maytag NFW7200TW Front Load Washer
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
How do you change the door on a Maytag 200 dryer to open right to left instead of left to right? Is that something that a homeowner can do?
Please specify the numbers on to machine data plate (serial, part #, etc.).
Some models do not have that option, but most Maytags do.
Aug 12, 2008 | Maytag Dryers
Can I change the way the door opens?
no you are stuck with the fact how they were buld.unless you want to mover the doorlock and all wiring and the hinge.
also have to make a hole for the doorlock.
I would not advice this.
May 02, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool WGD5300S Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
