Question about Maytag Neptune MAH5500B Front Load Washer
How do I get rid of mold on the seal ? - Maytag Neptune MAH5500B Front Load Washer
    New Friend:
Only removal of standing water is not enough for flooded home. For overall safety of home one need to be more cautious with after affect of floods like humidity, moisture and dampness in the atmosphere. All these factors lead to germination of molds in home. Within 48 hour mold can overburden home by its serious effect. To overcome such issues it is expected to hire black mold removal service in Nassau County New York for better results. ProRestore Damage Restoration Help For Flooded Basement Needed To Be...
Posted on May 19, 2017
    President:
  • 1,273 Answers
Hi, There is a lot of good advice on YouTube. Type in "smelly washer" or "washing machine mold" and you'll have lots to consider.
Best regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 29, 2009
    Scholar:
  • 117 Answers
Bleach and water solution will get rid of the mold but will not deter future buildup. To prevent future growth of mold leave door open to dry out. Mold likes to grow in damp dark places. Hope this helps
Mold in bosch nexxt 100 series- how to get rid of it?
yes bleach and a very hot wash. but remember mold grows in damp /wet so always leave door and soap draw open when machine is not in use this will dry out parts and cut down on mold growth ,
Sep 09, 2016 | Bosch Washing Machines
It has a musty smell
Step one: Identify the source. Try switching to a high efficiency powder detergent instead of liquid. (Suds collect in nooks and crannies.)
Step two: Clean. First wipe the inside of the washer, especially the area where the door seals to the inside. Mold can collect around the insides and folds of the rubber seals. Get in there and make sure you cleaned it all. You could use bleach or Pinesol.
Step three: Use a quarter cup of dish washing detergent (powder is best, liquid if you must), along with a towel. Put the machine on the "sanitary" (hottest water) setting. Let it finish its cycle. This should get rid of the mold completely.
Step four: Leave the door open between wash loads. This will decrease the mold build-up as it allows the tub to dry completely
NOTE: IT WILL TAKE 2-3 WASHINGS TO TOTALLY RID THE CLOTHES OF THE MUSTY SMELL.
Hope it helps!
Aug 22, 2011 | Whirlpool Washing Machines
I have a frigidaire front load washer and the rubber seal if full of mold. How can I get rid of it?
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump
Oct 23, 2010 | Frigidaire ATF6000ES Front Load Washer
The boot keeps getting moldy..yes, I ALWAYS leave the door open..even dry the folds with a towel. Its only a couple of years old! I have looked at other people's front loading washers..and noticed their...
In order for you to get rid of the mold, you have to get rid of it. Wash your boot seal with vinigar followed by bleach and antibiotic soap. Make sure to rinse well before loading any clothes afterwards. It would not hurt to run vinigar through your wash cycle followed by bleach either. You have to kill the mold or it will keep coming back and soap skum is a breeding ground for mold.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
Clean with bleach solution and a Mr Clean Magic eraser.
leave the door open to dry out the machine from now on.
Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My LG front loader washing machine has a black scum all over the rubber seal and it gets on my clothes and WILL NOT come out once it is on the clothes. I have tried bleach to get the stain off my clothes...
this is mold due to the amount of moisture built up during your wash cycle clean the scum using bleach but do not shut your door after you wash so the seal has an opportunity to dry
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Mold around the rubber seal in the front loader. how to get rid of
aliitle amount of vbleach on a damp warm rag shoudl remove the "mold", cut back on the amount of fabric softener and make sur eyour using an HE detergent ( A MUST FOR FRONT LOADERS)). keep the door ajar between loads will also lessen the build up
Nov 06, 2008 | Washing Machines
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
597 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
