I have a carrier split unit model#38HDL024311. It's dripping out the front of the unit. When I turn it off, There's a stream of water out the front also.
    Problem Solver:
  • 14 Answers
Where is water dripping? Out the outside unit or inside? Evap. Coils (indoor coils) condense when cooling so it is necessary to have a condensate drain hooked up. If the unit is leaking out of something besides the drain like out of the coil case then you have a blockage in your condesate line either in the drain pan under the coil or somewhere in the line that leads to your drain. blow the line both ways with nitrogen or pull the line out and clean it with a hose.
Posted on Jul 29, 2009
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
My Carrier split unit model 42KGA007 splashes water through the evaporator
The water drain hole is pluged, you need to restore the water drain circuit.
Aug 25, 2014 | Carrier Heating & Cooling
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
Shortly after starting up my split unit water began dripping from the bottom of the unit and running down the wall. How do I gain access to the drip gutter to check for a blockage? Or any other ideas...
The drain going out the bottom of the unit is clogged up...
To access this you will need to take the front cover off of the unit and blow out the drain with compressed air...
Then you will not have the dripping problem anymore...
Wish there was an easier way to clear it, but there is no easy way...
heatman101
Jun 25, 2011 | LG Heating & Cooling
Carrier split unit aircon mdl 42P100c has water dripping from the unit mounted internally onto floor.
Due to non maintenance of a/c. Col and air filter dust blocked. Due to this, some time ice formation over the coil will be there. Clean air filter, coil and blower wheel. And also drain pan.
If you see any ice formation over the coil after service, it's meant for short of gas. Thanks.
Jan 11, 2011 | Heating & Cooling
Carrier Air conditioner. Turn the unit on and the Green unit light is flashing. But the system will not turn on. Have tried replacing battery in the contol, and the air filters have been cleaned.
make sure your getting power to unit is this a split or package if split make sure water is not in exterior drain pan this will kick the float switch out push contactor in see if it comes on if not check the capacitor please give me a rating and vote
Sep 19, 2010 | Carrier Heating & Cooling
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
452 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
