Question about Konica Minolta magicolor 2490MF Laser Printer
No dail tone to fax. Do I connect the machine directly to the phone outlet? It's now connected to my computer and network.
  • 748 Answers
Hello
Yes the telephone line must be connected to do faxing.
Posted on Jul 29, 2009
It does not produce a dialing tone and it doesn't fax nor recieve
Here are some things to check:
1. Is the unit attached to a direct line (not one that goes through a local PBX)? Many fax machines have problems with internal connections.
2. Is the phone line connected to the proper port? The port for the external phone normally will have a picture of a handset. The other port is used to connect to the phone outlet.
3. Try a new phone cable between the fax and the phone outlet.
Here is a link to the user manual if you do not have one:
https://content.etilize.com/User-Manual/10203508.pdf
Apr 29, 2015 | Brother Mfc-8220 Laser Multi-Function...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Why no dialing tone on fax machine?
Unplug the phone calde from the fax machine and plug it in to phone. Do dial tone, is the other end connected to the outlet in the wall? Do you have a phone line to use as a fax line?
May 19, 2014 | United Stationers Samsung Scx4521fg...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
I can not send a fax with samsung scx-4521f
do a simple test. press the onhook button to you hear dail tone. try key in your mobile number and see if you got the call.
if all the above is yes there is no issue with the modem.
if you did not hear any dail tone. check your phone line is it working fine.
make sure that your phone line is not hunting line. fax machine does not work with hunting line. only direct line.
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Has no dailing tone.
Is the phone line working properly? if yes : check your NCU borad
May 11, 2010 | Canon FAX-B840 Plain Paper Bubblejet
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
We have recently purchased a brother mfc-240c, and as far as i no i have installed it correectly yet when trying to use the fax it dails a dead tone and continues to redail but doesnt send, and we...
make sure you have a dial tone by plugging a different phone into the jack. then make sure you have it plugged into the jack on the fax that says line.
Mar 08, 2008 | Uniden Cordless Phone
Phone
Make sure the phone cord from the wall is plugged into the outlet on the machine marked LINE and not PHONE.
Dec 28, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Konica Minolta magicolor  2490MF Laser Printer Logo
79 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
