Question about D-Link Xtreme N DIR-655 Wireless Router
I just moved to a new place and had my cable internet modem is hooked up. i can connect directly to the modem to get on the internet but cannot connect via my wireless router when i move the ethernet cord to it. i am using a macbook
    New Friend:
  • 63 Answers
I assume that you have a new modem in your new location. If this is the case, you need to clone the MAC address in the router setup (see online manual) OR you can reset the router to factory default state.
Posted on Jul 29, 2009
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
Trying to hook up my xbox to the internet, I moved everything out of the spare bedroom to the living room. problem is the nearest phone jack to hook up the cable to the modem is in the kitchen, or do I...
Hello noah757702
In order to connect to Xbox 360 your modem would need both cable and phone jack, first ethernet cable connected from Xbox 360 to the modem and modem in turn should be connected to the phone jack to complete the connectivity set up, let me know if you need more info on this
Nov 17, 2009 | Video Game Consoles & Games
For some reason when I hook the Router up I can not get onliine on any computer that I have the router for. I just moved and it worked fine at the last place. But the system light blinks. I forget if that...
Blinking shows activity, Double check how you have it hooked up....If you are using Internet connection sharing you should have your modem hooked throught your pc and your pc hooked to the #1 slot on the router...If you have your router connected to the modem its self make sure that you have it connected to the internet port of the router......If this is all set up properly hit the main reset (little black button on the back of the router) hold it for 30 seconds. Another possibility is firewall conflicts. Get back with me and let me know if this worked out for you...If not there are alternate directions we can take to solve this issue as it can be a number of things
Oct 06, 2009 | Dynex DX-E401 Router
Just moved had phone service and internet togather . Now I have cable and internet togather forgot how to connect router to modem this one doesn't have a place to put phone connectors in the modem
Most routers only have Ethernet connectors, so you should connect the cable modem to the router with an Ethernet cable. Generally, it goes into a port labeled WAN or Internet.
Aug 09, 2009 | Computers & Internet
I've recently moved into a new place and got the right password for the internet and it will let me connect. However, it is only with limited access for some reason and when I try to get on the internet it...
the 'gateway' for the new place changes from place to place. So, you have to call on the ISP(internet service provider) to get the new configuration done for your computer.
thanks.
Jun 08, 2009 | Microsoft RCA CABLE INTERNET MODEM MODLE...
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
How to run cables from router and modem and home coputer and new laptop
connect cable from modem to router ( place it on the internet slot) then plug the cable from your computer to router placing it in any of the four slots available in the router ( it is numbered 1-4) and hook it up , then do the same thing to your laptop. this sample connection is the usual router structure you may have.
Jul 22, 2008 | Computers & Internet
D-Link Xtreme N  DIR-655 Wireless Router Logo
107 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
