Question about GE GTS22KBP Top Freezer Refrigerator
Making a weird noise. sounds like water running but nothing leaking
  • 27 Answers
If the fridge and freezer are still getting cold it is either just the sound of the refrigerant moving through the system or i would try checking the drain incase it has iced up
Posted on Jul 29, 2009
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
Water pump; My 1990 Buick Century is leaking what looks like water or antifreeze, it's probably a mix of both because we have been putting water in the radiator. But everytime I park my car for a...
if you have the cooling system pressure tested this will show where the leak is coming from as there are frost pulgs and intake/headgaskets and other things that could be leaking.but pressure testing is the way to find what is leaking for sure.the rad may be full as it will draw water from the overflow bottle until its empty.if you didn`t have this problem until after the plugs were changed then it could be a hose that is leaking that was leaned on or moved to much.again pressure testing the system will show were its leaking.the whining noise could be antifreeze that has gotten on something causing the noise.
Sep 14, 2011 | 1990 Buick Century
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My air conditioner is making a noise and leaking!
mcdevito75 here, Have your A/C looked at by your local A/C repair shop. Sounds like the compressor is makeing the noise (expensive repair if so)
Jun 22, 2010 | Goldstar KG6000R Window Air Conditioner
Water valve not working and leak under dishwasher
The water leaking causes the float switch to activate the drain pump and as long as there is water in the pump housing area that is the only thing that will run.
Remove the water from below the unit and it should run long enough to trace the leak.
The easiest way to access this is to uninstall the unit and remove the lower back panel. remove the water wih a shopvac
remember to shut the power off.
Apr 01, 2009 | Viking Dishwashers
Started a load of laundry water filled fine started washing and agitating and then heard a weird noise like something got stuck and went and it sounds like motor is running but will not agitate or spin and...
Please give a make and model of washing machine. I suspect that something has stripped out between the motor and the transmission, which is the noise you heard.
Jan 24, 2009 | Washing Machines
Kenmore ultra wash 665.16761690
If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
See here about leaks and noise
It's noisy
It leaks
Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
GE GTS22KBP Top Freezer Refrigerator Logo
1,348 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
