Question about Furuno 1623 Radar 16nm Range
The top half of the dome blew off while towing boat. Any way to replace the top half with a used or new piece? Don't need to replace the whole dome.
    Scholar:
  • 76 Answers
As long as no damage was done to the enclosure from the lid blowing off, there is no reason that you can't simply put a dome on it. Try contacting furuno direct to see if the part is available. Make sure you know exactly what model radar you have before you call.
Furuno Tech Support : 360 834 9300
Posted on Aug 12, 2009
When on my boat transporting. Should motor be up or down or half way up?
i would say fully up because if its down it may scrape against the ground half way up should be ok as well if the boat came with a motor support structure rest the motor against that simply lift the motor up then back down onto the support if none came with the boat half way up or fully up will keep the motor blades safe from scrapping against the road while in tow
Aug 22, 2017 | Boating
PANASONIC M# TH42PX80U S# MA80430252 WHEN UNIT IS TRUNED OFF IN ABOUT 15 TO 2O MIN. IT STRATS CLICKING LIKE IT'STRYING TO TURN ON , BUT WHEN WE HIT THE POWER B. IT COME'S ON. IT TURN ON AND OFF OK....
That problem is usually happen when the power supply board got faulty by means of dropping voltage down due to some reasons like leak capacitors,cold solders etc..
try to inspect the capacitors that encircle on the picture below if it is look like bulged/dome on the top that is indication of faulty capacitors need to replace it with the same value..
But as you stated you replace that board 4 weeks ago then it helped for 4 weeks..I think the board you replace is used or refurbish not brand new right?..Because some of used/refurbish board is not long last but some are last a year/s..Try if you see the leak,bulged or dome on the top capacitors on that board try to replace it so you don't need to buy the board again..But if you don't see the bulged capacitors on that board try to replace the whole board again but its better if you look for brand new..Because some faulty capacitors are no indication but the value is change..
To learn more about capacitors just watch this video:
Hope it helps:
just keep on touch to fix your TV and get back the excellent quality of your TV again..
regards,
Chester.
Feb 03, 2012 | Panasonic Televison & Video
Pump needs replacing
I have the Bissell Big Green model 1672 and have used it for many years. Recently, the fan or suction blower began to emit a burnt smell so I shut it off. I had difficulty figuring out how to dissemble the top motor unit. Here is what I found.
Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Now, beneath the air outlet is the rest of the motor unit. The motor unit consists of three pieces. The bottom piece is the lid to the waste water receptacle. It is concave pointing down (lid shaped). The top piece is the domed lid for the motor unit. The middle piece is a flat plate between the other two pieces. The top of the flat plate (inside the unit) has mountings for the suction fan and the pump.
The flat plate is bolted to the bottom piece and the top piece (domed lid) is simply snapped down to the flat plate. If you take a flashlight and look inside the area where the AC cord is stored, you can see that the domed lid is a distinct piece from the flat plate. The model 1672 and 1680 (or 1680-3 if you wish) are nearly identilcal.
To access the internal parts in the motor unit, you cannot pry between bottom piece and the the flat plate because they are bolted together. But you can remove the top domed lid. To remove the domed lid, position the motor unit in front of you with the switches at 9 o-clock. Three snap-downs which attach the domed lid to the flat plate are at 1 o'clock, 2:30, and 7 o'clock. Wedge a flat bladed screwdriver or pocketknife between the edge of the domed lid and the flat plate at those locations and the lever the domed lid out and then up. The domed lid will separate from the bolted-together flat plate and bottom piece.
Wiring from the switches remain attached to to the electrical components. You will see that the AC cord has white, black, and green wires. The green ground wire connects to the fan ground at the 9 o'clock position. The white power connects to upper connector on the pump and also to the fan at the 7:30 position. Black feeds both switches on model 1672 and then a black wire runs from the correct switch to the bottom connector on the pump or to the connector on the fan at the 1:30 position.
Model 1680 has a third switch which feeds power to the floor sweeper. It has its own connection to the green ground and white power and goes through the third switch to connect to black.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping2_bing.gif, but some will want to charge you $80.
Feb 15, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
My roper washers top half of the agitator stoped
you will need a flat blade screwdriver long plyers 7/16 socket and ratchet, the verry top of the agitator prys off look verry close you will see a spot to put the screwdriver, then take the plyers and carfully reach in side and pull on handle of the domed shaped piece gently. then remove the 7/16/ nut. then lift off the corkscrew top portion of the agitator. you will see 4 tear drop shaped pieces called dogs part # 80040, look at the way there in there so they can be put back right later, use a camera take pictures as you go to each step for reasembly.the thrust washer will probly need replacing to, it's the plastic washer that the cork screw part sits on. when you go to put it back together use some vasaline where the dogs go in the holder, this will help hold them in place durring assembly. look close at holder for square holes they need to line up with the flat pins on top of lower portion of agitator. use an exstention and a large socket to hold dog holder in top in agitator top wile puting it on lower half. use the bag the dogs came it to hold the bolt in the socket til you get it started, then pull bag off before tightening. use two exstentions to put inner cover back in then put main cover on you are done,be pacient this may test your pacients.
Jan 08, 2010 | Roper Washing Machines
How are the two top sections held together? I need to get at the wiring.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping, but some will want to charge you $80.
Nov 30, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pump will not run
You will need to disassemble the top motor unit and try putting power directly to the pump. The switch may be bad, the connections may be dislodged, or you may need to replace the pump. I am reading your question and I assume that you cannot hear the pump kick on (low thrumming sound).
Here is how to disassemble the motor unit. Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Nov 01, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Split hull
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Jun 01, 2009 | Boating
The reostat that controls dome light and dash lighting-meltdown
As the voltage from the battery drops, the starter will draw more current, which may have caused the fuse fry - more likely, the connection between the fuse and the socket was worn, causing an arc in the socket, effectively welding the fuse to the socket. You can try using a piece of wire to jump across the two silver tabs on the top of the fuse, and seeing if you can start the car, but eventually, that fuse has to come out.
Mar 12, 2009 | 2005 Toyota Corolla
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1623 Radar 16nm Range Logo
87 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
