Question about Garden
I have a john Deer XT140 weed trimer and I dont have the fuel mixture for it
  • 636 Answers
Safe side 40:1
Posted on Jul 29, 2009
I would like to know the year and the type of fuel it takes gas or diesel fuel 450 C John Deere ser # 2810741T
diesel engine ,219 cu" (3.6L) turbo charged made by john deer
crawler loaders were made in 1965
Jun 23, 2017 | John Deere Garden
I need a manuel for a Weed Eater String Trimer model W25SKF Speficically the primmer bulb to the carberator
Not sure what you are trying to do or if this will help, but it is a parts diagram of every part. The next is a You Tube video that shows how to take apart and many more weed eater videos to choose from.
http://m.tractorsupply.com/ProdContentPDFs/4041511_Man1.pdf h
How to Replace Trimmer Fuel Lines
May 05, 2015 | Garden
My John deer start and then die replaced the fuel filter
There are not of reasons for lawn mover starting and then dying.
Please see this John Deer site for possible causes and fixes.
Troubleshooting
Sep 03, 2014 | Garden
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
How to proceed starting a homelite weed trimer for the first time in over eight years.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, @@
Dec 31, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
Manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
Oct 12, 2009 | John Deere Garden
2 cycle gas mixtures
a safe mix is 25:1 but the correct mix for that machine is 32:1
Jul 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
