Inverter is not charging battery, battery is ok.
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
SOURCE: MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
SOURCE: i am using microtek 810.
If this is a 12 volt battery situation, 24.6 volts is not doing good things for your batteries--it will buckle the inner plates causing immediate battery failure. Were the fuses themselves blown or just the fuse mounts which may have been underrated. You definitely need a schematic for this system--try googling 'microtek 810'. Good luck!
SOURCE: Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
