Optics Logo
Richard Ernst Posted on Oct 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Did national geographic purchase a video of a tornado for $1M?
Elizabeth
Level 2:
Sergeant:
  • Expert 123 Answers
  • Posted on Oct 08, 2017
Elizabeth
Expert
Level 2:
Sergeant:
Answers
123
Questions
Helped
52629
Points
521
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 13, 2009
SOURCE: Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Anonymous
  • Posted on May 24, 2009
SOURCE: I need instructions for the National Geographic Rock Tumbler.
Complete instruction manual to be found following the following link: http://www.sbdirect.biz/_download_files/NG09.pdf (my son also lost the instructions and I had to search the web to find another copy...
Anonymous
  • Posted on Nov 04, 2009
SOURCE: Free Download
i need to put code in so i can down load on my micro sd how do i do this please and thankyou
Anonymous
  • Posted on Nov 06, 2009
SOURCE: How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
Anonymous
SOURCE: dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Software for National Geographic 265NC
I tried the software that came with the National Geographic weather station 265NC but found it not what I wanted for history data. I downloaded Cumulus software from Sandaysoft.com I have used it since 2009 and have had no problems. When setting up the station on the software use Fine Offset as a menu selector for type of station as that worked for me.
How do i use the peice that hooks up to your laptop?
This is NOT a computer controlled scope--
http://www99.shopping.com/xPO-National-Geographic-National-Geographic-70mm-Compact-AZ-Refractor-w-table-top-tripod-
You probably have some kind of CD disk that has a planetarium program on it.
Here is a review of the telescope.
http://www99.epinions.com/reviews/pr-National_Geographic_NG70CA_Telescope
1helpful
National geographic telescope NG 114mm 900 EQ Who makes this telescope and would you price this at $150.00 ( used)
Manufacturer is unknown for this scope, but it probably originates in China and is resold with the National Geographic brand name, 150$ seems a little high for a used one. I would probably price it at 100-125$ depending on the condition and the included accessories, if any.
How do I fit an eye piece into the focusing tube of a National Geographic 76mm Reflector telescope where the screw is missing? Any idea where to purchase these specialised screws in Dublin ?
Any well stocked hardware store will have the proper "thumb" type screw. Take the part with you so you can get the correct thread for the screw. Nothing "special" about the screws.
3helpful
3answers
I just received PNY 4GB memory card as a gift. Anote behind the product says "to redeem" go to www.pny.com/ngbonus. When I try this website I get FixYa website..????
This is the site it should take you to...
http://nationalgeographic.pny.com/
It says this on the page...
Special Bonus Offers
Thank you for purchasing a PNY memory product!
Select downloads of images, maps, videos, music, games, and ringtones from National Geographic
13helpful
3answers
Mar 16, 2009 • Toys
Top National Geographic Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a National Geographic Optic Expert? Answer questions, earn points and help others
