SOURCE: insignia converter and sylvania tv no channels or signal
just you will find how.. http://www.youtube.com/watch
SOURCE: advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
SOURCE: how do i hook up an antenna to a samsung tv model no. cxj1952
If the set only has a coax cable fitting and you have a antenna with flat wire--you need the adapter that takes the flat wire and slides onto the coax fitting.
Once done in the menu you have to set the set to cable and operate the auto program etc.
