Question about Building Materials
My Lift Master is closed with the remote when we leave home and then might be open when we return. A few nights ago, the garage opened by itself when my wife was home along. What is wrong?
    Top Expert:
  • 44,133 Answers
Someone may be cruising the neighborhood with a Lift Master remote looking for burglary opportunities.
Posted on Oct 08, 2017
frcs68
  • 1605 Answers
SOURCE: My lift master garage opener opens randomly
change the security code in the opener and the remote.
seems like omeone in your are have the same frequency remote.
Posted on Nov 13, 2008
  • 3197 Answers
SOURCE: Garage Opener Model 3255 Chamberlain Lift Master
The most common cause of this problem is a bad wall control the wiring going to it. You can eliminate both temporarily by removing the wire at terminal 1 on the back of the motor unit. The wiring sometimes is shorted by the staples the installer uses. The wall control gets used a lot.
Posted on Jun 23, 2009
kb8dns
  • 494 Answers
SOURCE: Lift master Garage doors
Too much tension on the door can make the "brain" respond by opening the door, thinks something is in the way.... check for binding tracks or wheel guides, loose bolts, dry chain, tension on cables or springs ( be careful here), misaligned sensors....
Posted on Apr 06, 2010
swolfinor
  • 504 Answers
SOURCE: Help, my Lift-Master garage door opens 2-3 ft
SOUND LIKE A BROKEN SPRING.
LOOK ABOVE THE DOOR IF THERE IS A GAP IN THE SPRING IT NEEDS TO BE REPLACED,
I DO NOT RECOMEND THIS AS A DIY JOB. THEY ARE UNDER MUCH TENSION AND CAN COST YOU FINGERS IF YOU DON'T KNOW WHATYOU ARE DOING - CALL A PRO
HOPE THIS HELPS
Posted on May 26, 2010
swolfinor
  • 504 Answers
SOURCE: Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Merlin remote under alien control, help
Someone has a Merlin remote and is shopping around to find a house to burglarize. Once inside the garage, they are home free.
Jan 18, 2018 | Building Materials
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
Liftmaster 3265M Garage Door Opener opens on its own
Sounds like one of your neighbors may have recently replaced their own garage door opener and it coincidentally operates in the same frequency band as yours. One of them may also have purchased a new car and recently programmed it to open their door, but it inadvertantly interferes with yours. Depending on the quality of your door opener's receiver and how old it is, some receivers are not as good as others in their ability to discriminate against similar transmitted codes in the same frequency band. When the door opens by itself immediately go outside and see if a neighbor's door has just been opened (or closed) at the same time. Does your door open by itself at similar times during day? Like when a neighbor might be leaving or returning home from work? When someone uses a remote to close their garage door when leaving home, they (and the remote) are usually located in their driveway, but when they use it to open the door upon arriving home, they might be located right in front of your house.
Nov 25, 2012 | Home Security
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall...
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Nov 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not open or close with remote
What does a normal remote do with the lights?
Is yellow and green normal?
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jun 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close using remote unit.
It is an issue with safety eyes. Make sure both lights are on located on the eyes. If not, realign
Feb 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nov 12, 2008 | liftmaster Chamberlain Garage Door Opener...
Building Materials Logo
80 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
