Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I can see that the flap to the ice chute is not closing but I do not know how to fix it. How do I access this?
  • 77 Answers
Pull front plastic very carfully and clean this will usually fix the problem... if flap is in really bad shape replace ////////
Posted on Jul 29, 2009
The ice does not dispense from the chute. The chute freezes up and the ice can no longer travel down the chute and out the dispenser. Can this be fixed?
Yes the flap is supposed to close completly to stop the moist kitchen air freezing in the chute and blocking it
Sep 19, 2014 | Refrigerators
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flap does not close by itself, ice builds up on chute; when you put glass to fill, nothing comes out or an avalanche. Ice builds up in chute, flap won't close even manually. Ice maker stops producing.
I have had the same problem. The issue is with the solenoid that opens the flap. For a temporary fix you can just squirt some oil on it. Remove the control panel (pull it towards you from the bottom). Disconnect the three connectors. Then unscrew the four screws in the panel behind the cover. You will see the solenoid on the top right. Just squirt some oil on it and it should get it working again for a while. For a long term fix order a new solenoid, they are about $25.
Jan 22, 2010 | GE GSS25JFM Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer keeps running
yes,you need to pull the front panel on the ice maker off to get to the solinoid that opens and closes the flap,with the flap vranked open you are letting cold air out and warm air in and that makes frost,if you don't want to try and fix it your self put a cloth towel in the chute to block the air lose and call an honest local appliance repair person-mike
Nov 15, 2008 | Whirlpool Refrigerators
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
155 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
