Question about Kenmore Dryers
Need possible coil replacement. Is this complicated for someone who has not done dryer repair?
    President:
  • 1,273 Answers
No. It may be impossible for someone who's never done it, but nothing is impossible for someone willing to try. Get your replacement coils and tear your dryer down to the coils. Restring the coils, reassemble, and you're done!
There is an excellent series on YouTube entitled "Kenmore Dryer Repair" Look them over, and you'll be a pro at it!
Best regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 29, 2009
My Frigidaire front load dryer model number FEQ1442ES won't dry
First off clean your dyer vent tubes all the way to outside of you home. This could have been caused by clogged/ dirty vents
Ok so two possible problems.
1. The thermal fuse has blown. It stops the heating coils from working as a safety when overheated. To access your must remove the top cover. It is located towards the top at the right rear of your unit. To check it you need an ohm meter and must unplug the unit. There will be two wires to it unplug them and check for continuity between. If there is not it must be replaced (about $20). If it is bad replacing it should solve your problem.
2. The heating element has gone bad. This is a much more complicated repair on your unit and requires a lot of disassembly to even test. The part is about $80 and unless you are adept at taking dryers apart you might want to call a repairman.
For parts diagrams you could look up online. I use appliance pros but there are many others.
Hope that helps.
Dale
Nov 10, 2013 | Frigidaire FEQ1442ES Electric Dryer
Leaking back break lines
This is a serious problem. Depending on what material you use, and who works on this car, will directly reflect on the price of the repair.
Many of the replacement parts have to be hand fitted. Some preformed lines are available, but they are often sold as a complete set.
There are special tools needed to create a brakeline out of a coil of material. Each end of brakeline would need to be crimped with the correct fitting for the individual inlet hole. Using different sizes of fitting is the Manufactuers method to insure that the brakeline fits in only the correct place.
This made more sense when replacements were bolt on parts and readily available. Today though, it is a complication to buy different size ends for each brakeline.
You are going to want to go either to a Brakeshop or someone who has done this work before. Consider this, all Brakelines were installed the same day on the Assembly line. If 2 leak now, it won't be long before all 4 leak. If you do not know the History of the car, and what was replaced earlier, you need someone to inspect the brakes.
Oct 07, 2012 | Chevrolet Cars & Trucks
My GE dryer works but no heated or dry clothes
themobilian_70.jpgthemobilian_71.jpgthemobilian_72.jpgthemobilian_73.jpgthemobilian_74.jpg
Start by unplugging that machine. You know the fuse ain't bad because it still runs. So you must inspect the coilsthemobilian_75.jpgthemobilian_76.jpgthemobilian_77.jpgthemobilian_78.jpg
I have more photos and a video here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | Dryers
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 | Dryers
How do I locate coils
you need to remove the four door screws,
take off the door , remove the white cowel
remove the top dogs
open the top and look behind the tumbler
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Ice maker won't work and freezer is not freezing good
Take a look inside the freezer at the back wall. See if there is ice built up on it. If you have ice or frost on the panel, you either have a bad fan are you having a defrost problem. If I had to guess I would say a defrost problem. Unplug the fridge and remove the panel. Use a hair dryer to defrost the ice. There is a coil inside the ice so DO NOT TRY TO CHIP THE ICE OUT. just take the time and defrost it. After that is done, if you know how to use a multi-meter. You can check the heaters (Found inside the coils) to see if they have continuity. I would bet they don't. If I'm correct, you will need to replace the heater. Until you get the part or have someone to repair it, you can replace the panel, plug it back in and your fridge will work normally for around three days or until the coil builds ice back on it. This will give you time to either fix it or have someone to take care of it for you.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking Coolant - Water Pump Replacement
Depends on your experience, confidence, what tools you have and how much risk you can tolerate if you get into the job and can't finish it or do it incorrectly. A water pump poorly done could result in a damaged engine. It's a fair ways complicated for a novice but within the range of someone who's done brakes or replaced belts, hoses alternators etc. To see what you have to do, find a repair book for your car at the library. Otherwise it will cost somewhere around $200 to $400 depending how complicated the repair.
May 28, 2009 | 1999 Chevrolet Cavalier
DRYER NO LONGER HEATING UP
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 19, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Dryer not heating
No. And even if you could it would not be safe.
Today's dryers are full of safety devices and interlocks that insure that someone cannot just jumper the unit. Also, if you were to do this you might cause another component in the system to fail. Most of the units today use low current, low voltage devices that are microprocessor driven. A short across the thermal unit might not cause a problem but more than likely the microprocessor will shut it down because it doesn't expect a short other than as a failure mode.
There is possibly something else wrong with your dryer if the coil is not firing. It might be a burnt out coil. The best test is by removing the wires from the heating coil and using an ohm meter (ohms scale on an inexpensive multi-meter) to see if it is "open" (burnt out). If it is then replace it. I've done it a couple of times but would rather pay someone else to do it now.
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
