Question about Intex Pool & Spa
How do i prime my intex 2500 gph pump - Intex Pool & Spa
    Sergeant:
  • 242 Answers
Posted on Oct 14, 2017
3 Suggested Answers
  • 22 Answers
SOURCE: 2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
  • 27 Answers
SOURCE: How oprates the timmer in my 2500 gph intex filter pump
When the timer mode is set it will only run for the hours you have the knob positioned to. It will then shut off. You will need to restart it everytime.
Posted on Jun 25, 2010
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Intex pump strongly pulls water in, but the flow into pool is very weak. Air lock or dirty filter is not the issue. Any ideas? Many thanks! Anna
It is likely that your filter is dirty. The filter's cartridge can be removed and cleaned with a spray nozzle on a hose. you will then need to reassemble, prime and restart. I hope this helps.
Aug 08, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Model 635 will not pump water-ran it dry once.
If you ran the pump dry, it probably needs to be primed again. Make sure that you bleed the air from the line and get a good prime. In a worse scenario, it is possible that you burned up the motor in your pool pump. If this is the case, you will likely have to replace the entire filter and pump system.
Feb 04, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Jun 21, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How do you prime the pump for intex ubove ground
THIS HAS PRESSURE ON THE PUMP WHEN IT IS HOOKED UP TO THE POOL , NO PRIMING IS NEEDED. NOW IF IT'S HIGHER THAN THE WATER LINE OF THE POOL THIS KIND OF PUMP WILL NOT WORK , YOU NEED A PUMP THAT HAS A HAIR BASKET . THESE YOU FILL THE BASKET UP AND REPLACE THE LID AND YOU PRIMED IT.. . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Must pump remain below water level to work properly
I believe those pumps have no suction, and only pump out, thus they need to be primed to work. Gravity primes the modern ones. In the older ones, you primed them and essentially set up a siphon to feed it. So, yes, I believe they do need to be below water level.
Nov 25, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Leaky pump
There are rubber gaskets inside that get old and need to be replaced. Thats probably why it's leaking........Thank You For Using FixYa.Com! : )
Jun 17, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
The pump is making a loud noise.
Did you prime the pump? Is it pumping ok, or is it pumping dry? When does it make the noise?.. more info please...
Jun 08, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Pool & Spa Logo
111 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
