Question about Philips 32PT6441/37 32" TV
It does not respond to remote also has F at the right corner
Tv has F at the right corner
  • 1,694 Answers
Re: it does not respond to remote also has F at the right...
Install horiz driver kit # 483531057673 and replace 47mf/25v cap
in horiz driver circuit. Should reset after repair. Fix applies to all
L04.01U chassis.....................................T.
Posted on Nov 25, 2007
0 characters
3 Points
My tv screen just went blank with a small padlock on corner of the screen
Your TV has been locked by anyway. Refer its user manual to get details about how to unlock it.
Apr 04, 2013 | Philips Standard (CRT) Televisions
I have a logik TV RC-A22 there is a locked sign in red right top corner
Download the user manual to your Logik TV from net. It will have all details about the unlock procedure.
May 17, 2012 | Standard (CRT) Televisions
Screen locked remote no responding dropped remote screen blue with padlock in lower left corner no buttons working only off on remote
You can solved it by replacing the eeprom with the same and working tv. Or you can copy the working eeprom into your locked tv eeprom.
Aug 03, 2010 | Standard (CRT) Televisions
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
The channel stays lit in the upper right corner
Unfortunately, you almost always have to have the original remote control to get this display to go away. The "display" button is a specific code on that remote.
With Dish remotes, though, sometimes you can try different buttons and they will occasionally operate different functions. In TV mode, try the menu orother buttons to see if it makes a difference. My suggestion is to call a TV repair shop and see if they will allow you to borrow/buy an original remote for that TV.
Hope this helps you...
Jan 06, 2009 | Sanyo DS31590 31" TV
TV will not accept commands from remote or manually
I read other further along and found someone w/same problem. Solution was to hold display button for 10 seconds, it worked
Nov 22, 2008 | Insignia IS 20" TV040919 TV
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Standard (CRT) Televisions
Philips 32PT6441/37 32" TV Logo
101 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
