Question about Samsung Home Security
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
    Sergeant:
  • 85 Answers
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Posted on Oct 11, 2017
  • Marcus Inibehe Marcus
    Marcus Inibehe Marcus Aug 15, 2018
    Thanks a lot my DVR B74301n was rest after pressing UP, RIGHT and 5, 3, 3
SOURCE:
spinal
  • 287 Answers
SOURCE: Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Posted on Jul 31, 2008
RickOz
  • 145 Answers
SOURCE: Lost Admin password for SSL-VPN 2000
This is as close as I can come.
http://www.sonicwall.com/downloads/SSL-VPN_2000-4000_2.1_Release_Notes.pdf
Posted on Apr 10, 2009
  • 84 Answers
SOURCE: How reset/remove admin password
You can hack windows if you know how but otherwise there's nothing you can do. You will need to re-install your O/S from scratch and don't forget the password this time. Back up your important files & do a clean install.
Posted on Jul 24, 2009
SOURCE: forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Posted on Feb 23, 2011
SOURCE: I just buy a samsung 700t on ebay and it had admin passwordlock on it just want to know if i can reset it by myself
You'll have to login as an Administrator for it.
Posted on Mar 29, 2014
I need to reset my password on my Samsung digital recorder SDR-C75300N
Call 1-800-SAMSUNG (24/7) and they'll likely provide you the answer.
Sep 26, 2018 | Samsung Home Security
Samsung sdr-c5300n we just had to replace the router and now it hardly loads at all or very slowly. We have the arris frontier router, i did the port forwarding for 80 and also for 4520-4524 per inst
No goals stated at all , PC networking is complex, both in functions possible , speeds and firewall protections.
NO ISP stated nor OS used. (if PC is evolved at all, TV only?>)
A NEW SDR added?
What loads slow? SDR Or router , or PC or? define "Load." please.
Sorry, we are not a ROUTER networking forum of any kind.
here are 2, top ones. there are many,.... fixya is not in top 100.
https://www.bleepingcomputer.com/forums/f/21/networking/
http://www.networking-forum.com/
opening ports the first time?
most ISP block port 80. (fully or in part)
in part, they see, lots of data there and block it.
Use any port, not 80.
I have 4 web cams all using special ports, just for that rule alone.
with unique ports, like 1000 to 1003 that my ISP allows.
I am sure Im late to the party. 3 months late.
Jul 25, 2018 | Samsung Computers & Internet
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
Reset password samsung SDR-5102
By default, initial ID and password are set to "admin", and "4321
Jul 30, 2014 | Samsung 8ch Dvr 4 Camera System 19" Lcd...
Ssc21web password reset please! I tried HTTP and it asked for username and password. I tried root/root, root/admin admin/admin, etc. but nothing worked.
Samsung told me the newer versions of Windows and Internet Explorer, will not work with this system. Microsoft told Samsung it was their problem. Find a old computer with ME and Explorer 5 and it will work again. I have the ssc17web.
Oct 09, 2009 | Samsung SSC DVR Digital Video Recorder...
Home Security Logo
6,078 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
Daniel
Daniel
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
