Question about Acer Aspire 5610-4648 Notebook
Help my cam image is upside down.. what the hell happen? how can i fix it? thanks.
  • 383 Answers
Go to start - add and remove programs re-move the cam completely and re-start your computer and than re-stall the cd's again read the instructions and do what it says and than (re-boot your computer after you have finished restalling) the cd's.
Posted on Nov 27, 2007
Web cam upside down
WEBcam Image Settings
Check the WEcam settings. Most WEBcam have a setting to invert and mirror the image
Nov 17, 2012 | Computers & Internet
Inverted image crystal eye
It may happen if the WebCam position is upside down. Was it dropped or open by any chance?
You can follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow on screen instruction.
NOTE: This will erase all the data on the computer.
Thanks and regards,
Nov 23, 2011 | Acer Aspire 5515-5187 Notebook
When broadcasting on the internet with my cam, my image is displayed upside down. How can I control the angle for the cam?
This may happen because of improper setting of your webcam.
Please follow the below steps to make it fix:
Click on Messenger and select My Webcam
A window will popup on that window click on FILE menu and select Preferences and choose Webcam
Click on Camera setting
Generally there is a button with a check-box saying Invert Image or Mirror Vertical. Un-check it and click on Apply and Ok.
This will definitely solve your problem.
Sep 10, 2011 | Compaq Computers & Internet
My webcam on my Asus k501 is upside down. I use LifeFrame. How do I fix this problem?
If by upside down you mean that the image you see on the screen is inverted, then the settings of the webcam have been tampered with. When you launch your web cam, you would see the 'settings' option. Then select 'camera/image'. You would see the 'rotate' option. Rotate the image until it is erect. Also, if there is a 'flip' option, select flip vertically to make the image erect.
I hope that has fixed your problem?
Have a wonderful day.
Jun 23, 2011 | ASUS K50IJD2 Notebook
My web cam image is upside down...... how do i fix it?
I'm not sure what application you are using the webcam in but if it happens to be skype, perhaps this will help:
In skype options; go to video settings. Click the webcam settings button, this will open a "capture properties" window. in this window, test checking the "mirror horizontal" check box.
Hope this helps ;)
Jan 27, 2011 | ASUS K61ICA2 Notebook
My webcam image is upside down on massenger....How can i fix it ?
Windows Live Messenger Camera Image Upside Down(Iinversed Image) is the issue.You have probably tried to debug the problem with no result. Every information you found on the internet or what you were told to do yielded no benefit. You restart your computer depressing F8 to see if in safe mode things can be alright yet there is no difference from the normal system mode. This prolem has something to do with your system camera driver you installed or perhaps there is no cam driver installed in your system. Sometime it can be caused by the inverse system tool incorporated into the windows live messenger video section. Nevertheless, the best way to get your video image upright is as follows:
Uninstall any cam driver you installed in the system before(for those of you who have tried everything possible yet with no result).Also uninstall the windows live messenger from your system
Goto google search engine and type ccleaner and download it to clean the system and fix the registry editor.
Get your cam drive ready for installation. For those of you who doesn't have a cam drive you can go to google search engine to download possible one that is compactible with your system.
Run the installation wizard of the cam driver and install it.
Download windows live messenger from the internet .
Check your webcam or rather the video section of your windows live messenger if is upright now.
NB: If the video image is still upside down you will have to check you cam driver installed in the sytem from the control panel and untick inverse.
Jan 02, 2010 | ASUS F3Jc Notebook
My asus x59sl cam is upside down helpe me
There is a setting for the camara. Find the camera in the device manager then use the right button and click for properties , if that don't work look in image etc setting with the control panel select your camera, right button click, properties or it may be called settings and either tick or untick the 90 degree rotation or upside down setting
Dec 21, 2009 | ASUS F3Jc Notebook
Normal 0 Try this, while the computer is running and the picture is upside down, unplug the camera from the USB Port , wait a few seconds and then plug it back in. I have fixed several that had the same problem by doing this.
Worth a try.
Hope this helps. Bud
Jan 03, 2009 | A4tech Xmaster PK-835 Webcam
Ok im not sure what cam you have or comp that your using, but cahances are you need to go to your web cam settings:START/ALL PROGRAMS/ "your cam"/ CAM SETTING. there you should see inverted or mirror settings, it might even be in ADVANCED SETTINGS try and look for it, Good luck JLS
P.S. you could always turn your cam upside down! LOL Just kidding!
Sep 21, 2008 | Acer Aspire 5610-4648 Notebook
Yahoo! Messenger > Yahoo! Messenger Help > Messenger 8 > Webcam How do I correct an upside-down image? That’s no fun. The image in your Webcam Uploader window might be inverted because of your camera setting.
To change the setting:
Click Messenger and select "My Webcam."
In the window that opens, click the "File" menu,
select "Preferences," and choose "Webcam".
Click the "Camera Settings" button.
There is usually a checkbox for "Invert Image" or "Mirror Vertical."
Un-check this box if one exists.
If you can't find this checkbox, try searching the other tabs.
Nov 22, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
