Found the manual but nothing about the sound.
If I recall sometimes the part that makes the sound can be damaged when replacing the battery, open it up and check the (little wire type vibrating bar) sound bar and adjust if necessary.
http://www.casiodigitalwatches.com/manuals/0809.pdf
Testimonial: "Cheers. Does the bar need to make contact with the case? Should there be something on the backside of the case, i.e. tape?"
SOURCE: Took a battery out, put it back in and it wouldn't turn on.
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem.
SOURCE: TC 1490 Micro Media Lab Amplifier Repair
Dara1,
Its worth repairing if it is repairable provided the cost is minimal compared to what u spend buying it.
Siliconchip.
SOURCE: Need to Re-Assemble my Graco Snug Ride Car Seat
Hi jessibee
I found the site that you need to get an instruction manual for the seat. You will need to find the exact model of the SnugSeat that you have, because there are quite a few to choose from.
to find the model/serial number...
Car Seat
Toddler or Booster - On the back of the car seat OR on the bottom of the seat
Infant - On the back of carrier OR on the bottom of carrier OR on the stay-in-car base
Thanks for using FixYa, a Fixya rating would be great for this advice.
Good luck.
regards
robotek
SOURCE: How do you set up window range?
or press ZOOM, option 6 (ZStandard). That instantly resets the window range.
SOURCE: onkyo A-809 amplifier.... i want to get this
http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/A-809-_E
Follow the link and you can download the manual for free.
thank you,
Lee
If I recall yes it would touch the white disc on the inside case.
