Question about Toshiba TLP S30 Multimedia Projector
No signal projector (TLP-S71)message connect to laptop
I am trying to connect my laptop to a projector and I get a "no signal" message from the projector.
  • 2,237 Answers
Make sure the cable is good. then make sure the resolution matches.
Posted on Aug 04, 2009
  • TanyaKate8
    TanyaKate8 Apr 24, 2014
    Im sorry but this isnt a very clear awnser how do u check the resolution?
No input from Acer Laptop
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either an icon which could be a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 22, 2011 | Toshiba TLP-LV1 Projector Lamp for...
Connecting projector to Dell Vostro 1500 but getting no signal message
Press <Fn><F8> to switch the video image between the display only, the
external device only, or the display and the external device simultaneously
Feb 17, 2010 | Toshiba TLP S30 Multimedia Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Video Projector from Toshiba
I think it might be the video player or it might be the computer settings and the projecter settings.
Jan 06, 2009 | Toshiba TLP-S10 Multimedia Projector
TDP-S20
Click the 2 box on the display settings and put a check mark ano the box that is say to extend the view on to this monitor. Hope this Helps.
Jun 17, 2008 | Toshiba TLP S30 Multimedia Projector
N o signal
Hi momawarbucks
Check if your secondary screen is attached by going to desktop and right click , then go to properties and advanced.
Also check if your refresh rate is on 60-70 Hz
And that the resolution your PC is on , is supported by your Projector - i.e. XGA Projector - 1024x768
Good luck and thanks for using Fixya !
May 17, 2008 | Toshiba TLP S30 Multimedia Projector
Unsupported Signal
Hi Circuitrider
Just change the resolution on your PC to match that of the Projector i.e. XGA Projector = 1024x768 resoltuion.
If the problem still persists , the Mainboard is at fault and will need either replacement or repair.
May 13, 2008 | Toshiba TLP S30 Multimedia Projector
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Office Equipment & Supplies
Toshiba TLP S30 Multimedia Projector Logo
533 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
