Question about RIM Blackberry Curve 8300
Blue led light stays lit ; and none of the buttons work, an the phone is locked and impossible to unlock.
    Brigadier General:
  • 7,752 Answers
You need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...it has for every phone i fix that just have a blue led..also if the DM does not see your PIN, remove the battery from the phone then connect it again you should see BB PIN:UNKNOWN just click next and you should be good to go.
Posted on Jan 30, 2010
The display cannot be seen, as the blue background light has slowly went dim.
10 years is not quick in my book 2 weeks might be and I have seen LEDs die in less than a month .
Jul 11, 2015 | Dehumidifiers
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
How to unlock lock code for nokia C6-00
There are several tricks to unlock/reset codes but I found none works perfectly.Without repairing tools it is very hard......So, my comment is to visit your nearest mobile repairing shop.There they can generate the current code moreover they can reset it to default 12345 without missing any user data.Thanks for visiting fixya
Jun 06, 2012 | Nokia C600 Professional Blue LED Car...
Out of nowhere, the doors will not lock or unlock when armed, the blue led light stays on constantly after the car is turned off and the horn no longer honks when arming or disarming.
The system is in valet. Press the "F" button twice then, press unlock. This will take the system out valet. This will handle the blue light/horn honk. As for the door locks, that may very well be another issue.
Jun 16, 2011 | 5101 LE 1 Way Car Remote Starter System
Keyboard on 3yr old Dell desktop PC not working. There is a lighted padlock looking icon on the keyboard that is lit but none of the keys seem to work. any suggestions?
Try pushing the FN key at the same time as you push on the lock key this may unlock the keyboard I think you are in the locked position there is a FN key this is the blue highlighted key to make all the blue keys work you have to press it simultaneously. I hope that this assisted you. Thanks for using FixYa John
Apr 06, 2011 | Dell 0Y3740 Keyboard
Blue led stays on instead of blinking .
disarm system get inside the car turn key to ON position with door OPEN push the black valet button one time turn key off
now your out of Valet mode
or
open your door hit ARM then DISARM then ARM and that should also remove Valet mode if you don't know where the valet button is at.
May 14, 2010 | Viper Security and Remote Start System...
Alarm Light constantly lit
You are in valet mode. It means the vehicle will lock/unlock but not arm the security system.
Open the door then hit lock then unlock and lock. Led will now turn off and work as normal.
Apr 04, 2010 | 821001/2100 2100 Security System
Only the printer led is lit
Are there any lights on? If not, then have you checked the power supply, and the wall sockets. Sounds like that may be your problem?
Feb 25, 2010 | Draytek Vigor 2910G Dual WAN secure...
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
Blue light will not stay lit
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 30, 2008 | Motorola Mobility H700 Wireless Headset
RIM Blackberry Curve 8300 Logo
370 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
