The power jack is making sparks, and the notebook has no pwer
The power jack is making sparks, and the notebook is not starting, do you know what partnumber does the powerjack has? i have a Lifebook A6010 Thanks
Marius
  • 748 Answers
Hello
I repair many of these every day. Most manufacturers won't give out part numbers for individual parts. The best option is to allow a company like mine repair this, unless you feel confident working with an exposed motherboard. Once you have the motherboard exposed it's fairly easy to compare the jack to ones available online.
Posted on Jul 29, 2009
No spark to spark to sparkplugs no pwer to fuel pump 1997 ford f150 4.2 liter
Check coil packs, distributor, etc... gotta have spark to make it go.
Jun 08, 2015 | 1997 Ford F150 Regular Cab
Will not boot up, screen is blank power light comes on for a few second, then turns off
Either your DC jack is bad the motherboard is bad or the power supply is bad. The DC jack on that one is NOT soldered in and fairly easy to replace if you know how to tear it down. Toshiba uses a clip in clip on DC jack instead of soldering them to the board. Start by ohming out the power supply make sure its placing out the correct amperage. Thibk its around 1.58 amp at 19volts. You can see 4 sure looking at the label on it. If its good I would take it to a qualified shop to have the DC jack and board tested to see which is causing your power issue. The average replacement laptop board is $285 not including labor. DC jacks run about $5 but the labor should run around $100
Sep 17, 2010 | Toshiba Satellite A200-0ET00X Notebook
Okay if my gateway m285 pc tablet wont turn on how do i know if its the charger or the battery itself?
just do a simple test. plug your charger in AC mains, at the jack end, insert a wire and then try to make instant contact with the jacket of the jack. you will see a brief spark. If spark is there, it means your adapter is good. rest you know that if charger is ok and still laptop is not working it means that there is something wrong with the power section inside the laptop. Even with a bad battary, if adapter is good, laptop will work, provided power section of the laptop should be ok.
cheers
Sep 04, 2010 | Gateway M285-E Notebook
How to replace D620 power jack? pwer jack is "loose" causing intermittent connection with power supply. the problem is "not" power cord.
The power jack is located on the motherboard. It is soldered to it. You have to remove the screws behind the laptop securing the back cover and disconnect the hard drive and GPU cables remove the keyboard so that you can pull out the motherboard. This is necessary since the solder joints are located under the motherboard and the jack is over it. There are 3 pins that are soldered. Remove the solder on all 3 and pull out the jack. Insert the pins of the new jack in the space vacated by the old pins and use a low diameter solder(2mm or less if available and lead free solder only) to solder the pins to the board and voila!
May 18, 2010 | eMachines eMD620-5133 Notebook
I have an old compaq evn n610c. I had some problems with it for a while where I had to wiggle the power cord a little to get it to power on with the cable. That worked for a while and then one day it...
Hello,If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack((DC jack)) is broken or loose.
If the power jack is broken you can replace it if you know few things about soldering;)
If the power jack is not broken but loose (not making good contact with the motherboard) you can re solder the old jack without replacing it with a new one.
Jan 20, 2010 | Compaq Evo N610C Notebook
BIOS wont start
Check the battery voltage. The battery may have failed and is overloading the AC pwer supply.
Aug 28, 2009 | Acer Aspire 5315 Notebook
Pwer adaptor wiring jack plug
try ebay the mite have some lala linda www.ebay.com
Jan 05, 2009 | HP Compaq nx6110 PC Laptop
Power Jack
Most, if not all computer manufacturers do not include these instructions, & for good reason too. You should not attempt to replace a DC Jack if you are not very technologically savvy.
Repairing the actual DC Jack itself requires you to strip the notebook down to the motherboard. From that point you will need to de-solder the old DC jack (very carefully) and then solder a new DC jack to the motherboard. After those steps are complete, you need to test the power using a voltmeter. If the voltage matches up to that of the computers you can continue. After you have finished all of that the only thing left is to put the notebook back together.
More detailed instructions as well as photos can be found by doing a Google search. Try entering the make and model of your specific notebook.. Who knows, you may get lucky and find a link with how-to photos.
Mar 18, 2008 | Gateway 400SD4 Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
