Question about Pit SSR 110CC Pro Beginner Bike
When i give my pit bike throttle it cuts off, when it first starts its real low rpm and when i give it throttle it makes a grinding sound and dies, i can restart it but it keeps doing it
Mine doesn't do that, it will run on half or full choke as soon as I take the choke off, it dies entirely, I leave the choke on, and try giving it gas, and it'll backfire out both sides. Which is telling me not combustion all fuel, I've taken the carb apart a couple times, nothing is clogged left air fuel mix screw how it was, and cleaned the carb, re assembled a few days later, snapped a chain and had to replace the Magneto on my flywheel pulled it and hasn't ran right since.. and I took tha left side cover off today, and had score marks on side of my flywheel think I should get new flywheel and Magneto?
Posted on Mar 16, 2013
    Problem Solver:
  • 8 Answers
Check first your carburator settings to make sure that it is running properly and not choked. If that doesn't solve it then there could be something broken or messed up anywhere from in the clutch system to the gearbox depending on what the drivetrain is.
Posted on Jul 28, 2009
1200 sportster 2009 fuel inj cuts out at 3000 rpm with throttle open
Before you even start looking at your bike you need to find the fault code
How to access fault codes and what they mean, once you know the code then it makes life easier here is a link of how to retrieve the codes and what they mean, its good to print this off and keep for future use
http://www.thunder-max.com/techdocs/HarleyDiagCodes.pdf
Oct 02, 2016 | Harley Davidson XL 1200 C Sportster Custom...
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
163FML (CG200) bogging at low rev
Hi, Marcus and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Bogs when open the throttle fast
Motorcycle Message Board Motorcycle USA
boging and half throttle
boggs down when accelerate aggressivly to full throttle Pit Bike Club
Why is the engine bogging under acceleration Suzuki FA50 Moped
Bike dies when you give it throttle
Mar 17, 2017 | Motorcycles
1984 honda vt500c cuting out
How about a fuel filter? does your bike have one?
Mar 31, 2012 | Honda VT 500 C Shadow Motorcycles
I have a ssr 125 pit bike it starts fine but when you give it a little throttle it starts to sputter a little . it seems to run fine once you get going .i just finished breaking it in its got 2 hours on...
It sounds like you need to overhaul and clean out the carb. There may be jets and passages partly clogged and are restricting your fuel flow at wider throttle settings.
Mar 29, 2011 | Pit SSR 110CC Pro Beginner Bike
Bike is cutting out and dies out when you throttle hard. symptoms of water in fuel, bad plugs, or flooding out. Pipes are black inside and black is coming out. I have put heet and foam in gas tank - put...
make sure they are the right plugs, i have had many a yamaha rider swear they put the right plugs in and found out that they used the wrong resistance plug. there are two types of plugs, resistor and non-resistor, if you use the wrong type the bike will idle fine and even run ok at low rpm, but as soon as you throttle on, it sputters and wants to die, check that first and repost.
Aug 22, 2010 | 2007 Yamaha Royal Star Tour Deluxe
My pit bike wont stay runnin
sounds like your carb could be blocked with dirt if it wont start unless you put juice down plug i would take the carb off and give it a good clean and also make sure the jets ok just clean them with carb cleaner and a paper clip
Aug 06, 2009 | Pit SSR 110CC Pro Beginner Bike
Pit SSR 110CC Pro Beginner  Bike Logo
792 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
