Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
SOURCE: No TV "Select Source" Menu Option
Had the same problem and found on the back of the tv on the black box that the cable hooks to there is a plug at the top of that box on the left side came loose. If you slide that box to the right you can completely remove it from the tv. Reinstall it and make sure it's plugged in tight your tv setting should come back.
SOURCE: lost remote on toshiba w528
You can select those to record with out the remote by setting the record timer to record. For example, if you want to record from one of those input channels on Friday 1 January 2009 at 9:00 to 11:00, it will allow you to choose that as an input channel in that program menu. If not, you will want to buy a replacement remote. VC-522 is no longer available, but VC-617 and other models are.
SOURCE: remote wont work and can't acess menu with tv
Turn your Sony Bravia on by pushing either
the power button on the front of the TV or the power button on the
remote control, which is located in the upper right corner of the
remote.
Read more: How to Reset a Sony Bravia TV ' eHow.com http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html#ixzz1Cn2noiTF
SOURCE: video is snow. no images just lines and snow. the
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Testimonial: "I talked to TV techs, family, friends and co-workers and no one had an answer to this problem. I tried your suggestion and it worked like a charm! "
