Question about Acer Aspire 4315 Notebook
Where can i find the charger on the acer aspire 7520 motherboard?
  • 4 Answers
This one fits:
http://cgi.ebay.com/AC-ADAPTER-CHARGER-FOR-ACER-ASPIRE-5100-5001-5050-5102_W0QQitemZ300303537493QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45eb7c5555&_trksid=p3286.c0.m14
Posted on Jul 28, 2009
How to stop my aspire acer 7520-5071 from turning on and off.
replace the charger if this doesnt help perhaps the power socket has bad solders or connections and the machine will need to have the socket replaced this is defo a job for a tech
Dec 05, 2014 | Aspire Acer 7520-5071 Notebook
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
Acer Aspire 7520 will not boot but the green standby botton keeps blinking
Remove the main battery and power up, if no change sub out the ram memory one at a time, still nothing it is time to have the motherboard checked.
May 29, 2012 | Acer Aspire 7520-5185 Laptop
Acer Aspire 7520, running windows Vista, keeps overheating and shutting down. It is fairly new - less than a year old. Does not run for much more than 20 minutes before shutting off. It was purchased in...
Sounds like there is dust where the cpu fan is and its blocking the ventilation path in the laptop. If you can take apart the laptop to expose the fan, I would make sure the fan is free of debris. Clogged CPU fans will cause the laptop to overheat cause the air has nowhere to go.
If you do that and the laptop is still overheating then the motherboard is going bad unless your not using the correct charger for it. If you use a charger that puts out more voltage then whats needed then that could cause the laptop to overheat so you might need a new charger.
Apr 15, 2010 | Acer Aspire 7520-5185 Laptop
ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
Apr 02, 2010 | Acer Aspire 7520-5185 Laptop
Acer aspire 7520 laptop has overheated diodes on motherboard
what is the start up issue, how far dose it go. do you get the login
Mar 09, 2010 | Acer Aspire 3680 Laptop
Acer Aspire 7520 EVERYTHING IS HUGE
I'm suspecting a faulty driver. Try searching " (model number) Motherboard driver".
May 07, 2009 | Acer Aspire 7520-5185 Laptop
Acer Aspire 4315 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
