SOURCE: Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
SOURCE: can't get red eye reduction to work
When the small photos appear, select the one you want to remove the red eye.
SOURCE: Monitor comes on and displays small box of monitor
It does the same when attached to another PC? It can be bad caps, lamp assemblies, etc. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
You could try connecting an external monitor with whatever graphics port you have available (VGA, HDMI or DVI.) It may not show your screen automatically, but it's worth a shot. Otherwise, take it to a computer shop and have a nerd try and save your hard drive data.
Testimonial: "Thanks for the reply but i can get the HD out if that's what i wanted but what i'm trying to do is work on the computer untill i have enough money to buy replacement scree,.do you have any other way i could possibly change the setting in vaio control?"
SOURCE: Blue screen with a small box in the center of it that displays exit. Would not let you boot up
Hi Cathy this is Alex Walker expert to help you for this issue call +1(404)981-1535 I will be glad to assist you thanks
Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
Tap or click Adjust resolution.
Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Control Panel: Display: Appearance tab: Advanced button
Control Panel: Display: Appearance tab: Advanced Appearance dialog box
To open the Ease of Access Center, select:
