Question about Dyson Vacuums
Dyson vacuum turbo head for carpet just spits thing out instead of sucking it up.
  • 6 Answers
Check your filter it maybe clogged.
Posted on Oct 07, 2017
reddevil6
  • 1673 Answers
SOURCE: Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Posted on Feb 14, 2008
SOURCE: The bissell proheat turbo carpet
Bissell cleaner will not **** up water???
Posted on Sep 14, 2008
  • 97 Answers
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Posted on Jul 29, 2009
heatman101
  • 43501 Answers
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jer
Posted on Sep 30, 2010
How do i fix my Bissell pro heat turbo x2 carpet cleaner it wont suck up anything?
Check the vacuum hose and head for link clogs from carpet fibers
Oct 30, 2016 | Bissell Vacuums
I can't push my Dyson Dc33 on my new carpet..it works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC29 Animal Vacuum
Why is my dyson dc25 spitting hair back out?
Hi there, it's Jack at Dyson.
If any debris is coming back out of your DC25's cleaner head, it's very likely that you have a blockage in the cleaner head or the airway it's connected to. To check the cleaner head itself, please follow the steps shown in the video below:
To check for blockages in the airway and throughout the rest of the vacuum, please follow the simple checks shown in our online Support guide: http://www.dyson.co.uk/support/dc25/dc25-irsvsye/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
This should definitely help, but if you'd like any further advice from our experts, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 07, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson sucks good untill i put handle down
Try moving the floor/carpet selector dial on base of vac back and forth, from floor to carpet repeatedly, at least 5-6 times....it may be stuck
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have an animal dyson. The front nose dives into the carpet when moving the dyson in the forward motion, fine when pulling back. A huge amount of effort is required to move it forward. Took it to a...
Check bottom plate is corectly fitted.theres no height adjustment on them but they do suck down on longer carpets.u could try switching off beater bar on the side at front that may ease the effort
Apr 10, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brushes seem to stick and it is hard to push the dyson 07 along
it sounds like it is sucking it self to the floor. you may need to adjust the height adjustment for the head so it rides a little higher and wont stick to the carpet.
Oct 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Jan 24, 2010 | Dyson DC08 Cylinder Bagless Canister...
Carpet vacuum attachment quit working after sucking up a bedskirt. Bedskirt has been removed but carpet attachment will not work. My old vacuum had a reset button on the carpet attachment for use when...
I have a Hoover Conquest approx. 4 yrs old. The turbo head is not working Model No. PB4 230-240V AC 50Hz 200w CS4901N (N127) I have been trying to locate another one or another one similiar to fit my machine
Jun 12, 2008 | Hoover Vacuums
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
