SOURCE: 1998 pontiac transport montana power steering return hose
if it's the return hose, you can just cut out the bad part and replace it with rubber hose and clamps.
SOURCE: Check Engine Light On idling rough once car is warm
Your codes are as follows:
18010: "ECT Circuit High Input"
16684: "Random Misifre"
16685: "Cyl 1 Misfire"
16686: "Cyl 2 Misfire"
18010: "Voltage Supply Terminal 30 Voltage Too Low"
Your codes 16684, 16685 and 16686 are symptoms, not the problems. Obviously your engine is running roughly. So, once you get the problem fixed, these codes should go away on their own.
The 18010 code is normally displayed after the vehicle's computer has been re-set or replaced. If you've recently attempted to reset the computer in an effort to fix your issues, don't worry about this code. It too will go away when you get the main problem fixed. If you haven't reset the computer (or disconnected the battery for any other reason), then you'll want to check your battery cables and the power source cables running to your computer to make sure they're connected securely and are free of corosion.
Having said all this, we get to the root of your problem (code 16502). This code is triggered when your Engine Coolant Temp Sensor goes bad. The sensor typically sells for $60.
To remove and replace it:
To install:
Hope this helps and good luck!
SOURCE: 1999 grand am gt power steering presure hose
if you replacing only lines for power steering you dont have to take out the belt but on other side of linens are very hard to disconnect from the rack and pinion...
you have to lift and secure the front disconnect the lines from pump and fallow he lines and keep disconect the holders from the body when you rich the end you are right under the driver seat you will see the very little open space and you see the bolt that connects linen to rack and pinion you will need long wrench take it out..just take your time ..when placing the new line just make sure it seats good on place and you gonna need the bleed power steering system after changing the lines...
so finally this job is really hard to do if you don't have experience i recommended to you just bring somebody know what he's doing for save time and not to do some job double time.Power steering system is closed system air or heavy leaks can damage your expensive power steering pump and rack and pinion.
SOURCE: 1996 Jeep Grand Cherokee No Start
I would be thinking that there is a good chance that you need to be checking out replacing the computer, if you aren't getting any communication with the proper scan tool then the computer isn't communicating with anything in the vehicle...... I would have guessed first off that the ignition control module might be bad but that is obviously part of the computer also, I would be looking in that direction.
