Question about Polaroid TLA-04011C 40 in. LCD TV
Changed parental code and didnt write it down. is
Changed parental code and didnt write it down. is there a reset?
    Problem Solver:
  • 5 Answers
You will need to contact the manufacturer. In some cases there are TECH codes that can access areas you can not. Hope this helps.
Posted on Jul 28, 2009
IF I WERE TO FACTORY RESET MY LEAPPAD ULTRA WOULD THE PARENTAL CODE BE DELETED WITH IT?
I'm in the same position! I have no idea what to do, did you find a solution? I haven't even been able to Factory Reset because i need the parent code :/
Oct 26, 2014 | LeapFrog LeapPad Ultra Learning Tablet -...
Bought a used tv that has a parental code on it. how do i reset or take off. Its a veiwsonic n2750W thanks
I think so unlock Parental Codes on most TV's you would go to where ever in the settings is asks to Remove Parental code. If they didnt really care hopefully the password would be generic like 0000
Dec 05, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
My PS2 wont allow me to watch movies about level 2. its getting to the point that i cant watch ice age. i tried 7444 but it didnt work. i bought it from Gamestop used and they said that they didnt know of...
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press and hold the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Aug 19, 2009 | Video Game Consoles & Games
Reset Parental Control
There you go:
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Jan 09, 2009 | Emerson EWF2004 20" TV
Password to delete or change parental code
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
THEN immediately afterwards, press DOWN, Y, UP, DOWN
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Dec 23, 2008 | Microsoft Xbox 360 Console
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Nov 20, 2007 | Sony PlayStation 2 (PS2) Console
Emerson sb350 ( spongebob dvd combo )
I had the same problem.I fixed it by unpluging the tv.Then while holding in the power button I plugged it back in,still holding in the power button for twenty seconds.That fixed it.I read somewhere you could reset a Sony that way so I gave it a try and it worked.I also put a cd cleaning disk in it because it was saying "wrong disk" and that fixed that problem.Good Luck
Aug 10, 2007 | Emerson SB350 13 in. TV/DVD Combo
Polaroid TLA-04011C 40 in. LCD TV Logo
127 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
