Question about Acer Aspire 5600 Series 5630-6951 Laptop
Ctrl alt f10 to reforrmat - Acer Aspire 5600 Series 5630-6951 Laptop
  • Lrobby14 May 11, 2010
    are you trying to reformat your hard drive with the recovery drive?
Will only run on safe mode
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
F10
Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate
load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Jul 08, 2013 | Compaq Evo D500 PC Desktop
Tip
Key-bord shorcut
· Shift + F10 right-clicks.
Win + L (XP Only): Locks keyboard.
Similar to LockWorkstation.
· Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs.
Win + Control + F: Open Find dialog. (Computers)
Win + U: Open Utility Manager.
Win + F1: Open Windows help.
Win + Pause: Open System Properties dialog.
· Win + Tab: Cycle through taskbar buttons.
Enter clicks,AppsKey or Shift + F10 right-clicks.
· Win + Shift + Tab: Cycle through taskbar buttons inreverse.
· Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog.
Alt + Shift + Tab: Display CoolSwitch; go in reverse.
· Alt + Escape: Send active window to the bottom of thez-order.
· Alt + Shift + Escape: Activate the window at the bottomof the z-order.
· Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog.
Shift while a CD is loading: Bypass AutoPlay.
· Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun)
· Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog.
· Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape.
· Printscreen: Copy screenshot of current screen toclipboard.
· Alt + Printscreen: Copy screenshot of current activewindow to clipboard.
Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. · Ctrl + Alt + Up Arrow: Undo inversion.
Win + B : Move focus to systray icons.
2.) Generic
· Ctrl + C or Ctrl + Insert: Copy.
Ctrl + X or Shift + Delete: Cut.
· Ctrl + V or Shift + Insert: Paste/Move.
· Ctrl + N: New... File, Tab, Entry, etc.
· Ctrl + S: Save.
Ctrl + O: Open...
· Ctrl + P: Print.
· Ctrl + Z: Undo.
· Ctrl + A: Select all.
· Ctrl + F: Find...
Ctrl+W : to close the current window
· Ctrl + F4: Close tab or child window.
F1: Open help.
· F11: Toggle full screen mode.
Alt or F10: Activate menu bar.
Alt + Space: Display system menu. Same as clicking theicon on the titlebar. · Escape: Remove focus from current control/menu, or closedialog box.
3.) Generic Navigation
Tab: Forward one item.
· Shift + Tab: Backward one item.
· Ctrl + Tab: Cycle through tabs/child windows.
Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows.
· Enter: If a button's selected, click it, otherwise, clickdefault button.
· Space: Toggle items such as radio buttons or checkboxes.
Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name.
Ctrl + Left: Move cursor to the beginning of previousword.
· Ctrl + Right: Move cursor to the beginning of next word.
Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls.
· Ctrl + Down: Move cursor to beginning of next paragraph.
Shift + Left: Highlight one character to the left.
· Shift + Right: Highlight one character to the right.
· Shift + Up: Highlight from current cursor position, toone line up.
· Shift + Down: Highlight from current cursor position, toone line down.
· Ctrl + Shift + Left: Highlight to beginning of previousword.
Ctrl + Shift + Right: Highlight to beginning of nextword.
Ctrl + Shift + Up: Highlight to beginning of previousparagraph.
Ctrl + Shift + Down: Highlight to beginning of nextparagraph.
Home: Move cursor to top of a scrollable control.
· End: Move cursor to bottom of a scrollable control.
on Oct 10, 2010 | Computers & Internet
Tip
WORD 2003 Shortcuts
All Caps Ctrl+Shift+A
Annotation Alt+Ctrl+M
App Maximize Alt+F10
App Restore Alt+F5
Apply Heading1 Alt+Ctrl+1
Apply Heading2 Alt+Ctrl+2
Apply Heading3 Alt+Ctrl+3
Apply List Bullet Ctrl+Shift+L
Auto Format Alt+Ctrl+K
Auto Text F3
Auto Text Alt+Ctrl+V
Bold Ctrl+B
Bold Ctrl+Shift+B
Bookmark Ctrl+Shift+F5
Browse Next Ctrl+Page Down
Browse Prev Ctrl+Page Up
Browse Sel Alt+Ctrl+Home
Cancel Esc
Center Para Ctrl+E
Change Case Shift+F3
Char Left Left
Char Left Extend Shift+Left
Char Right Right
Char Right Extend Shift+Right
Clear Del
Close or Exit Alt+F4
Close Pane Alt+Shift+C
Column Break Ctrl+Shift+Return
Column Select Ctrl+Shift+F8
Copy Ctrl+C
Copy Ctrl+Insert
Copy Format Ctrl+Shift+C
Copy Text Shift+F2
Create Auto Text Alt+F3
Customize Add Menu Shortcut Alt+Ctrl+=
Customize Keyboard Shortcut Alt+Ctrl+Num +
Customize Remove Menu Shortcut Alt+Ctrl+-
Cut Ctrl+X
Cut Shift+Del
Date Field Alt+Shift+D
Delete Back Word Ctrl+Backspace
Delete Word Ctrl+Del
Distribute Para Ctrl+Shift+J
Do Field Click Alt+Shift+F9
Doc Close Ctrl+W
Doc Close Ctrl+F4
Doc Maximize Ctrl+F10
Doc Move Ctrl+F7
Doc Restore Ctrl+F5
Doc Size Ctrl+F8
Doc Split Alt+Ctrl+S
Double Underline Ctrl+Shift+D
End of Column Alt+Page Down
End of Column Alt+Shift+Page Down
End of Doc Extend Ctrl+Shift+End
End of Document Ctrl+End
End of Line End
End of Line Extend Shift+End
End of Row Alt+End
End of Row Alt+Shift+End
End of Window Alt+Ctrl+Page Down
End of Window Extend Alt+Ctrl+Shift+Page Down
Endnote Now Alt+Ctrl+D
Extend Selection F8
Field Chars Ctrl+F9
Field Codes Alt+F9
Find Ctrl+F
Font Ctrl+D
Font Ctrl+Shift+F
Font Size Select Ctrl+Shift+P
Footnote Now Alt+Ctrl+F
Formatting Properties Shift+F1
Go Back Shift+F5
Go Back Alt+Ctrl+Z
Go To Ctrl+G
Go To F5
Grow Font Ctrl+Shift+.
Grow Font One Point Ctrl+]
Hanging Indent Ctrl+T
Header Footer Link Alt+Shift+R
Help F1
HHC Alt+Ctrl+F7
Hidden Ctrl+Shift+H
Hyperlink Ctrl+K
Indent Ctrl+M
Italic Ctrl+I
Italic Ctrl+Shift+I
Justify Para Ctrl+J
Left Para Ctrl+L
Line Down Down
Line Down Extend Shift+Down
Line Up Up
Line Up Extend Shift+Up
List Num Field Alt+Ctrl+L
Lock Fields Ctrl+3
Lock Fields Ctrl+F11
Macro Alt+F8
Mail Merge Check Alt+Shift+K
Mail Merge Edit Data Source Alt+Shift+E
Mail Merge to Doc Alt+Shift+N
Mail Merge to Printer Alt+Shift+M
Mark Citation Alt+Shift+I
Mark Index Entry Alt+Shift+X
Mark Table of Contents Entry Alt+Shift+O
Menu Mode F10
Merge Field Alt+Shift+F
Microsoft Script Editor Alt+Shift+F11
Microsoft System Info Alt+Ctrl+F1
Move Text F2
New Default Ctrl+N
Next Field F11
Next Field Alt+F1
Next Misspelling Alt+F7
Next Object Alt+Down
Next Window Ctrl+F6
Next Window Alt+F6
Normal Alt+Ctrl+N
Normal Style Ctrl+Shift+N
Normal Style Alt+Shift+Clear (Num 5)
Open Ctrl+O
Open Ctrl+F12
Open Alt+Ctrl+F2
Open or Close Up Para Ctrl+0
Other Pane F6
Other Pane Shift+F6
Outline Alt+Ctrl+O
Outline Collapse Alt+Shift+-
Outline Collapse Alt+Shift+Num -
Outline Demote Alt+Shift+Right
Outline Expand Alt+Shift+=
Outline Expand Alt+Shift+Num +
Outline Move Down Alt+Shift+Down
Outline Move Up Alt+Shift+Up
Outline Promote Alt+Shift+Left
Outline Show First Line Alt+Shift+L
Page Alt+Ctrl+P
Page Break Ctrl+Return
Page Down Page Down
Page Down Extend Shift+Page Down
Page Field Alt+Shift+P
Page Up Page Up
Page Up Extend Shift+Page Up
Para Down Ctrl+Down
Para Down Extend Ctrl+Shift+Down
Para Up Ctrl+Up
Para Up Extend Ctrl+Shift+Up
Paste Ctrl+V
Paste Insert
Paste Format Ctrl+Shift+V
Prev Field Shift+F11
Prev Field Alt+Shift+F1
Prev Object Alt+Up
Prev Window Ctrl+Shift+F6
Prev Window Alt+Shift+F6
Print Ctrl+P
Print Ctrl+Shift+F12
Print Preview Ctrl+F2
Print Preview Alt+Ctrl+I
Proofing F7
Redo Alt+Shift+Backspace
Redo or Repeat Ctrl+Y
Redo or Repeat F4
Redo or Repeat Alt+Return
Repeat Find Shift+F4
Repeat Find Alt+Ctrl+Y
Replace Ctrl+H
Research Lookup Ctrl+Shift+O
Reset Char Ctrl+Space
Reset Char Ctrl+Shift+Z
Reset Para Ctrl+Q
Revision Marks Toggle Ctrl+Shift+E
Right Para Ctrl+R
Save Ctrl+S
Save Shift+F12
Save Alt+Shift+F2
Save As F12
Select All Ctrl+A
Select All Ctrl+Clear (Num 5)
Select All Ctrl+Num 5
Select Table Alt+Clear (Num 5)
Show All Ctrl+Shift+8
Show All Headings Alt+Shift+A
Show Heading1 Alt+Shift+1
Show Heading2 Alt+Shift+2
Show Heading3 Alt+Shift+3
Show Heading4 Alt+Shift+4
Show Heading5 Alt+Shift+5
Show Heading6 Alt+Shift+6
Show Heading7 Alt+Shift+7
Show Heading8 Alt+Shift+8
Show Heading9 Alt+Shift+9
Shrink Font Ctrl+Shift+,
Shrink Font One Point Ctrl+[
Shrink Selection Shift+F8
Small Caps Ctrl+Shift+K
Space Para1 (single spacing) Ctrl+1
Space Para15 (one-and-a-half line spacing) Ctrl+5
Space Para2 (double spacing) Ctrl+2
Spike Ctrl+Shift+F3
Spike Ctrl+F3
Start of Column Alt+Page Up
Start of Column Alt+Shift+Page Up
Start of Doc Extend Ctrl+Shift+Home
Start of Document Ctrl+Home
Start of Line Home
Start of Line Extend Shift+Home
Start of Row Alt+Home
Start of Row Alt+Shift+Home
Start of Window Alt+Ctrl+Page Up
Start of Window Extend Alt+Ctrl+Shift+Page Up
Style Ctrl+Shift+S
Style Separator Alt+Ctrl+Return
Subscript Ctrl+=
Superscript Ctrl+Shift+=
Symbol Font Ctrl+Shift+Q
Task Pane Ctrl+F1
Thesaurus RR Shift+F7
Time Field Alt+Shift+T
Toggle Character Code Alt+X
Toggle Field Display Shift+F9
Toggle Master Subdocs Ctrl+\
Toggle XMLTag View Ctrl+Shift+X
Translate Pane Alt+Shift+F7
Un Hang Ctrl+Shift+T
Un Indent Ctrl+Shift+M
Underline Ctrl+U
Underline Ctrl+Shift+U
Undo Ctrl+Z
Undo Alt+Backspace
Unlink Fields Ctrl+6
Unlink Fields Ctrl+Shift+F9
Unlock Fields Ctrl+4
Unlock Fields Ctrl+Shift+F11
Update Auto Format Alt+Ctrl+U
Update Fields F9
Update Fields Alt+Shift+U
Update Source Ctrl+Shift+F7
VBCode Alt+F11
Web Go Back Alt+Left
Web Go Forward Alt+Right
Word Count List Ctrl+Shift+G
Word Count Recount Ctrl+Shift+R
Word Left Ctrl+Left
Word Left Extend Ctrl+Shift+Left
Word Right Ctrl+Right
Word Right Extend Ctrl+Shift+Right
Word Underline Ctrl+Shift+W
on Dec 03, 2009 | Computers & Internet
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
others you might try
Acer: - Ctrl+Alt+Esc
Sep 27, 2012 | Sun Blade 2500 PC Desktop
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
Press delete enter to set up so what can i do nothing is working
Sound you are trying to get into the BIOS, some use key F2,F8, or F10, it will say very fast what the correct key is, it might be very fast.
The first item is the key or key combination. The second is the model of PC or the maker of the BIOS. You'll see some companies listed many times, with different keystrokes. That's normal. (It's not that manufacturers can't make up their minds. It's just that they change suppliers and use different BIOS setups.)
Delete: AMI or Award BIOS.
Esc: Toshiba
F1: Toshiba; Phoenix; some IBM PS/1 models.
F10: Compaq.
F2: NEC.
Insert: IBM PS/2.
Tab: eMachines.
Reset button (press twice): Some old Dells.
Ctrl-Alt-+: Various computers.
Ctrl-Alt-?: Some old IBM PS/2 models.
Ctrl-Alt-Enter: Some Dells, others.
Ctrl-Alt-Esc: AST, Tandon, others.
Ctrl-Alt-Ins: Zenith PCs, Phoenix BIOS.
Ctrl-Alt-S: Phoenix BIOS.
Ctrl-Alt-Shift with Del (on number pad): Olivetti.
Ctrl-Esc: Many PCs.
Ctrl-Ins: Some IBM PS/2s.
Ctrl-S: Phoenix BIOS.
Ctrl-Shift-Esc: Tandon
Dec 02, 2009 | Acer Aspire™ T180 PC Desktop
How to get into bios
Restart the computer and press F2 right away.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Can not get laptop to enter bios
On many of the MPC laptops, the bios can be brought up at boot by pressing the F2 key. Generally, while booting, the screen will show you the button to push. Here are some more of the most used key combinations you can also try. On our mpc support site, there is no manual available yet for this model. Also, mpc laptops have the capability to lock out the bios at users request so many used models obtained cannot be changed. We'll have a new support site for mpc up this summer. Details at mpcsupport@cox.net
Most of the time during boot-up the key (combination) will be shown. If it is not, then you could try the following key combinations:
  • Del
  • F1
  • F2
  • F10
  • Ins
  • Esc
  • Ctrl+Alt+Esc
  • Ctrl+Alt+Enter
  • Ctrl+Alt+Ins after Ctrl+Alt+Del
  • Ctrl+Ins
  • Ctrl+Alt+S
  • Ctrl+S
  • Ctrl+Shift+Esc
  • Shift+Ctrl+Alt + Num Pad Del
  • Ctrl+Esc
  • Ctrl+Alt and +
Dec 25, 2008 | MPC Computers TransPort T3000 Notebook
Old computer
You can try "Ctrl+Alt+Esc";
Additionally, to restore Acer BIOS - press and hold the F10 key while powering on;
Others you can try are: F1, F2, Esc, Del & F10
On some really old machines:
CTRL + ALT + INS
CTRL + ALT + ENTER
CTRL + ALT + S
PAGE UP KEY
PAGE DOWN KEY
Hope that this be of some help. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 12, 2007 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
1,093 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
