Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Picture - with sound but right speaker turns off and on.
The left speaker is constantly working normal but the right speaker turns off and on.
    Problem Solver:
  • 5 Answers
If these are the speakers attached to the unit you have either a bad internal amp or a bad speaker. try switching speakers and see if it still n the RIGHT if so its time for a service call
Posted on Jul 28, 2009
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Need the speaker diagram wiring for a 97 chevy tahoe
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 01, 2018 | Car Audio & Video
Where do I pug the speakers in ? I need a Picture,Show me the picture.
    • 1 Remove the Dell A215 speakers from the box. Place the speakers in your computer area. The speaker with the volume knob is the right speaker and should sit to the right of your keyboard. Place the other speaker to the left of your keyboard.
    • 2 Plug the left speaker into the right speaker. The left unit has an orange-brown plug that connects to a similarly colored port on the back of the right unit. The other end of the cord is fixed to the rear of the left speaker.
    • 3 Insert the two-prong end of the power adapter into an electrical outlet. Plug the other end into the black power port on the back of the right speaker.
    • 4 Insert the main audio cable into your computer. This cable is fixed to the back of the right speaker and has a green head. Plug the green connector to the green audio-out port on your computer. This port may be on the front or back of desktops or on either side of a laptop.
    • 5 Turn the knob on the right speaker clockwise to turn the speakers on and increase the volume. Turn it counterclockwise to lower the volume partially or all the way to turn the speakers off. The speakers should work automatically on any computer with a sound card.
Let me know if this solved the problem and good luck..
Sep 09, 2011 | Dell A215 Computer Speakers
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
PIONEER STEREO DXT-2266UB
----POWER---
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
----SPEAKERS----
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual = http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DXT-2266UB_OwnersManual0607.pdf
1997 PONTIAC FIREBIRD WIRE COLORS
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
Looking for picture wiring diagram for audio to hook up a radio in a 1989 plymouth sundance
1989 Plymouth Sundance Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Back Strap
Car Radio Dimmer Wire: Orange/White
Front Speakers Size: 5 1/4?
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Green/Yellow
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Purple/Yellow
Rear Speakers Size: 5? x 7?
Rear Speakers Location: Side Shelves
Left Rear Speaker Wire (-): Brown/Yellow
Right Rear Speaker Wire (+): Blue/Red
Right Rear Speaker Wire (-): Blue/White
Nov 24, 2010 | 1989 Plymouth Sundance
I have 4 wires, red (power(, black (ground), green (speaker), gray speaker...the stereo has these same color wires...so I connect the corresponding color. The boat has NO yellow battery wire that is on the...
(http://inform3.kenwoodusa.com/manuals%5CKTSMP400MR.pdf )
Here's a link to manual and wiring on page 30 on the PDF file.
Yellow is constant power from battery, for memory etc. Red should be to switched source.If need be, you can connect both to battery, but remember, you'll have constant power draw on battery when stereo left on but switch turned off, and will draw battery down, if you forget to shut it off, and leave the boat. Speaker negatives to black should work but I would advise hooking my 2 right and 2 left + speaker wires from stereo together, then to one of the speaker positives,right or left for better sound. Fronts will usually supply higher ( high and mid range), and rears will supply lower sounds (woofer) Joining them together will give better sound usually, when only using 2 speakers, on a 4 speaker stereo. You may want to test with them joined and not, to see what sound you like better.
Sep 26, 2010 | Kenwood KTS-300MR CD Receiver
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
2000 Hyundai Sonata radio wiring is not normal color coded.
Constant 12V+ Red
Switched 12V+ White/Green
Ground Black
Illumination n/a
Dimmer n/a
Left Front (+) Brown/White
Left Front (-) Black/White
Right Front (+) Brown/Yellow
Right Front (-) Black/Yellow
Rear Speakers 6" Rear Deck
Left Rear (+) Brown/Red
Left Rear (-) Black/Red
Right Rear (+) Brown/White
Right Rear (-) Black/White
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 11, 2009 | 2000 Hyundai Sonata
Stereo theft
try this to see if the right wires are there it normally cost about 130 to get a professional to do it
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 25, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
