Question about Home
I don't know anything about plaster walls but I want to secure a pedestal sink against a plaster wall in my bathroom. Please advise the proper bolts, etc. to use and the proper installation technique. The pedestal sink has two bolt holes in the back of the top piece, and the bottom piece has two bolt holes that I can just screw into the wood floor.
  • 297 Answers
You can use a bolt called a molly bolt or a butterfly bolt. tyr to use the biggest bolt you can to fit the hole.and i would not bolt the leg to the floor,just sit the sink on the leg to get proper hight then screw to wall and chaulk the leg to the floor with clear chaulk.
Posted on Jul 29, 2009
Testimonial: "Many thanks for your very helpful advise."
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
Trying to mount a heavy piece of flat art on the wall, aproximately 72" x 48" and weighing 200 pounds. Trying to find a compatible hanging system
You need to know what the wall is made of - brick, block, concrete, plaster board, etc? Then go to a DIY store and ask - they'll advise you. If its an internal plaster-board wall then I doubt it will be strong enough. A while ago I hung a 4' x 3'6" mirror on a block wall using two fairly heavy duty rawl bolts and its still hanging.
Mar 06, 2012 | Televison & Video
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
I have a sink in bathroom I have removed cabinet and there is nothing to hold up sink can that be anchored it is round sink with 1/2 inch lip caulked to bottom of counter i also want to remove do i have to...
I DON'T RECOMMEND TRYING BOLT THIS TO THE WALL UNLESS YOU HAVE THE WALL BRACKET THAT COMES WITH THE SINK,NOT ALL SINK ARE DESIGNED TO BE WALL HUNG.
Apr 20, 2010 | Home
Installation instructions for a Glacier Bay Westminster pedistal sink
Things You'll Need:
  • channel lock pliers, mini tubing cutter, tubing cutter for 1 1/2" tubing razor knife, 24"level drill, 3/16"dia. drill bit
  • 3/8" drive ratchet and sockets, tape measure, Teflon tape, 8" adjustable wrench, black sharpie, small edges (cedar wood shakes) 3/8"x 3" anchor bolts, pedestal sink, faucet with pop up drain, P-Trap,
  • sponge, rags,
  • lavatory supplies
The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
  • Step 2 The drain for the sink needs to be set just right so that the finish work will go together easier. When setting the drain make the threads for the trap adapter stick out just past the finished wall. If the threads stick out to far then the escutcheon will not fit up tight to the wall. So check the depth of the trap adapter threads before putting the sink in place.
  • Step 3 Press the small foam pads adhesive side down on top of the pedestal. With the faucet and pop-up drain mounted on the basin place the basin on top of the pedestal. Move both pieces together up against the wall with the drain centered with the sink. Check the pedestal for level. If it is not level use the cedar wood shakes as wedges to make the pedestal level. Don't cut the cedar shakes yet this will be done later. Now adjust the basin to make it level as well. With the sink centered and level mark the points where the anchor bolts will go through the china into the wall. Many pedestal sinks come with a wall mounting bracket if yours does then slide the bracket up under the sink and make it tight up against the wall and the china. Be careful not to move the basin, if you have someone to help you have them hold the sink in position while you're doing this. Now mark the holes in the bracket where the anchor bolts will hold the bracket to the wall.
  • Step 4 Move the pedestal sink out of the way. Use the drill with the 3/16"dia. drill bit to drill pilot holes on the marks that you made. Next screw in the anchor bolts into the pilot holes. Make the wall mounting bracket tight to the wall. The anchor bolts that go through the china need to be removed.
  • Step 5 Take the lavatory supplies and wrap the tops of them with Teflon tape. This will create a gasket like seal. Attach the supplies to the bottom of he faucet. Make sure to get a good tight connection you don't want these to be leaking later on. Next take the J-bend portion of the P-trap and slip it on the tailpiece of the pop-up drain. Measure the height of the center of the drain where it sticks out of the wall. With the basin sitting on top of the pedestal put the p-trap together and make the trap arm the same height as the drain pipe. Mark the top of the J-bend on the tailpiece so you have a reference mark. Next take the basin off of the pedestal and tighten the slip nut on the J-bend. Make this connection secure it will be very difficult to get to this connection later on.
  • Step 6 Move the pedestal into position and set the basin on top of the pedestal. Check the small adhesive pads if they have fallen off stick them back in place. Line up the holes in the china with the holes in the wall and screw in the anchor bolts. Don't tighten these yet you still have to adjust the basin and level the pedestal. Put the cedar wedges back in place to level the pedestal and adjust the basin. Now that everything is level tighten the anchor bolts. Be careful not to over tighten the bolts they could crack the sink.
  • Step 7 Use the tape measure2_bing.gif and measure from the center of the J-bend opening to the trap adapter. Add about 1 1/4" to this measurement so some of the trap arm will be inside the adapter. Cut the trap arm to length with the tubing cutter. Next slip on the slip nuts and washers and don't forget the escutcheon. Install the trap arm. Catch the slip nuts with your fingers and tighten as much as possible by hand. Tighten the rest of the way with the channel lock pliers. You'll notice the first nut on the J-bend is almost impossible to get to that is why you must tighten it before you set the sink.
  • Step 8 Take the lavatory supplies and gently bend them to line up with the supply valve connections. Now mark the supplies where they will fit into the compression joint on the valves. Use the mini tubing cutter and cut on your marks. Slip the compression nuts and ferrules onto the supplies and put the supplies into the valves. Catch the nuts with your fingers and tighten by hand. Now finish tightening with the adjustable wrench2_bing.gif.
  • Step 9 Remove the aerator from the spout of the faucet. Turn on the hot and cold supply valves and run the water in the sink to flush out the lines. When the water runs clear put the aerator back into the spout. Close the pop-up drain and fill the basin with water. While it is filling check underneath the sink for any leaks and repair them if necessary. When the basin is full open the pop-up drain and let the water out. Check under the sink once more for any leaks and repair them.
  • Step 10 Use the razor knife to cut off the excess cedar wood that sticks out past the china on the pedestal. Next caulk around the base of the pedestal where it meets the floor. Also caulk along the top edge of the basin where the basin meets the wall. Dampen the sponge and wipe off the excess caulk to make a smooth caulked joint. Clean up and admire your handy work.
  • Mar 30, 2010 | Pegasus Technologies Home
    How do I replace the bath sink stopper lift using a Danco universal kit
    Things You'll Need:
    • sponge, rags,
    • lavatory supplies
    • Step 1 The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
    Mar 30, 2010 | Home
    I have bolted a pedestal sink to the wall. The pedestal is a separate piece, and is loose under the sink. Evidently the sink is bolted slightly too high, though I had the sink resting on the pedestal...
    Place spacers between sink and pedestal.You may need to replace current screws or bolts with slightly longer ones to compensate for the spacer thickness. Spacers could be almost any materiel but plastic or rubber would be best against water damage.
    Jul 08, 2009 | Home
    How do I remove the pedestal of my Kohler sink?
    The pedestal is caulked on top and buttom. remove the caulking you can remove the pedestal. make sure the sink is bolted to the wall, there should be 1 bolt on each side of the sink. (looking from buttom up.)
    Jun 10, 2009 | Kohler K-2223-7 Portrait Bathroom Sink...
    Remove the base of a pedestal sink.
    There are two bolts on either side of the sink. Remove them and lift the sink off of the base. Sometimes, depending on who installed it, you can slide the base out without removing the sink. Hope this helps.
    Mar 14, 2009 | Home
    Home Logo
    128 people viewed this question
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
