Question about Hotpoint HSS25GFP Side by Side Refrigerator
Icemaker makes to much ice - Hotpoint HSS25GFP Side by Side Refrigerator
    New Friend:
  • 63 Answers
The stop bar is a level switch that is either not rising or is defective. You can check with the a parts supply to see if you can purchase this switch separately. If you cannot, you need to replace the ice maker unit.
Posted on Jul 29, 2009
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    How to trouble shoot GE ice maker that is not producing ice
    Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    Ice cube tray won't stop making ice.
    This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
    Thank you
    Rick
    Mar 12, 2012 | Refrigerators
    Ice maker stopped making ice
    Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
    Aug 15, 2009 | Refrigerators
    Ice maker wont make ice
    Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
    Aug 12, 2009 | Roper Refrigerators
    Water but no ice. ice in tray
    If you have a "paddle" switch just below the icemaker make sure there is tension on it, i.e. the tension spring might be loose. Make sure the tension spring end is inserted into a tiny hole. Mine wasn't, I did it and ice maker works fine now.
    Jul 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
    Not making ice, indoor water spout working
    Check the temperature in the freezer. The temperature must be below 0 degrees for most icemakers to perform properly.
    Jun 14, 2009 | Refrigerators
    Kenmore Coldspot w/Ice Maker Not Making Ice
    hi LOP7,
    In most cases you can easily solve this problem.
    step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
    Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
    If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
    If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
    Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
    Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
    Icemaker want stop making ice
    The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
    If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
    If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
    You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
    Post back if you need instructions on reparing it.
    Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
    Hotpoint HSS25GFP Side by Side Refrigerator Logo
    Top Hotpoint Refrigerators Experts
    John Tripp
    John Tripp
    Sal DeAngelo
    Dan Webster
    Dan Webster
    Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
