Question about Hitachi 55HDS69 55 in. Plasma Television
Tv cycles on and off
Tv will boot up and show picture for about 1 to 2 secs then shut off. It just keeps trying over and over. The 5 leds show the boot sequence makes it till LED 2,3,4 at lit. Then it shuts down and recycles again. The service manual does not give indication what the 3 leds mean. Can someone help?
  • 3 Answers
I just went through this as many others have done so I am sure that Hitachi knows it to be a manufacturing and software problem but will not do right by the customers. Judging by the date of your request you may have already found the repair.
The main digital board (part #JP50763) on my 55HDT79 manufactured in Feb 2007 fouled and had to be replaced. It has the new software on it that is supposed to prevent the problem from recurring. Bad news is that the final cost to me was 25% of the original price. Just the board costs $433.00.
Posted on Aug 12, 2009
How do I fix my power cycling tv??
I have found that the solder connections get loose where they connect to the p.c.b. please make sure its not plugged in and don't touch the hv probe going to the tube. It will be the last time. Be extremely careful and keep one hand behind your back. If that's not it, the power supply has gone south. Get another TV.
Sep 03, 2015 | JVC LT-46P300 46" 1080p LCD TV - 16:9 -...
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Vs-50609
Good Day, checho3435;
Look for fluid on the PCB's or check these items:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source). Good Luck, big IRISH>
Jul 30, 2008 | Mitsubishi WS-55807 TV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Have a Panasonic Projection TV PT-47wx51c. It is currently shutting it self off, then the red light in the front blinks and can not be turned back on until it is un-plugged. Just befor it shuts itself...
can you determine if the led blinks a certain amount of times then a slight pause before blinking again? Let me know as it may be blinking a diagnostic code.
Mar 28, 2008 | Televison & Video
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Hitachi 55HDS69 55 in. Plasma Television Logo
511 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
