Question about Sony XM-2150GSX Car Audio Amplifier
Amplifier turns on but not the subwoofer?
I have a dual 12" subwoofer with amp. i hooked up the power cable to the positve battery terminal and the amp turns on fine but my subwoofer doesnt do anything i have the wires from the amp to the subwoofer connected and the ground wire mounted from amp. I also tapped a wire that i think was the wire that turns on the sub but not sure. I was wondering if anyone knows which wire it is from the original stereo system in a 1999 buick regal non super charged? and do i need a ground mount connected to the negative battery terminal? Need answers please.
  • 655 Answers
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Posted on Jul 29, 2009
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    Tip
    Solo x two amp usage
    you can run two amps on the solo x. one for each coil. positve and negative from one voice coil. positve and negative for the other voice coil. two amps one sub.
    on Feb 12, 2008 | Kicker 12" Solo X Subwoofer S12X - 5000...
    I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
    Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
    Aug 15, 2010 | Car Audio & Video
    NO BASS!!
    1) Check the Subwoofer for continuity - At the subwoofer, one at a time, test the terminals for Continuity using your Digital Multi-Meter; if your DMM doesn't have a Continuity test, use the Resistance, or Ohms, test and check for Resistance in the Subwoofer Coil (be sure to disconnect the subwoofer wiring before performing these tests).
    2) If they test out good, hook the wires back up and test the terminals at the terminal cup or at the Amp hookup if you didn’t use a terminal, don't hook it up to the amp yet. Sometimes the wiring inside the box can be a problem if it has come loose, or isn't making a great connection.
    3) If you have a Sub or multiple Subs with Dual Voice Coils, or multiple Subs with Single Voice Coils, make sure your wiring is correct by checking here:
    http://www.the12volt.com/caraudio/woofer_configurations.asp
    4) Make sure there are no Hi-Pass filters, crossovers, or multi Channel switches enabled.
    5) Replace your RCA cable/s with known working RCA cable/s from the Source/Head Unit to the Amplifier/s.
    6) Check your Head Unit settings; make sure the Bass is turned up and/or the Subwoofer setting is turned On.
    7) If you are still getting no or low output, try plugging in an MP3 player or CD player using a headphone to RCA adaptor and check for sound output. If there is still no or low output, your Amplifier outputs are probably burned out.
    Jul 18, 2010 | Jl Audio 300/2 Car Audio Amplifier
    I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
    You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
    Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
    1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
    2- Turn remote control knob to the mid level between min and max.
    3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
    4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
    5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
    Sep 06, 2009 | Car Audio & Video
    Amp overload protection mode
    it sounds like the ground is bad to begin with and check the positve cable for oxidisation on the battery terminal and at all other places that the power wire is connected to
    Aug 09, 2009 | Kenwood KAC-8104D Car Audio Amplifier
    Does not turn off and drains the battery
    do u have the amp hooked to a switched terminal of the igntion switch?
    Jul 22, 2009 | Insignia 600W Bridgeable Amplifier with...
    Let our Experts solve your "My amp lights up like normal then protection light red comes on and turns the amp off resets and tries again. What would be my course of action
    disconnect all wires (including RCAs)
    reconnect positive, ground, and remote.
    Turn amplifier (car) on.
    If it goes into protect mode again - there is an internal fault that requires professional repair.
    If the amplifier idles as normal - turn off the car. Plug in RCAs & re-try
    Failure? - replace RCAs as they may be pinched or faulty.
    Lastly if all connections are made and amplifier idles without going into protection - you need to concentrate on your load (subwoofers).
    Be sure they are wired properly into a resistance that amplifier is rated.
    The lowest impedence that amplifier is rated is 2ohm.
    That is possible with (2) 4 ohm subwoofers wired in parallel....
    (4) 8 ohm subwoofers wires in parallel...
    (1) Quad 1 ohm subwoofer...
    or (1) Dual 4 ohm voicecoil subwoofer.
    Any other combination will result in an impedence too low for your amplifier.
    Next:
    Using an OhmMeter (Digital multimeter set to Ohms 20) test each voicecoil against its advertised resistance. It should be CLOSE +/- .5 Ohms.
    Any other reading means the voicecoil is blown.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    May 27, 2009 | Kicker (ZX750.1) Car Audio Amplifier
    Trying to hook my amp up in my car, I already have everything but the main power supply which is the wire to the battery.I was wondering how would i do that the right way?
    the car amp needs to be wired using a +12 power, ground, and +12v signal (rmt) cables.  the +12 volt cable needs to be connected from the posative terminal of the car battery to a fuse (the right size should be written on the amp somewhere) then to the +12v on the amp. the ground cable needs to be connected to the negative terminal of your car battery. the RMT is the more complicated one, this needs to be connected to the header unit or the ignition switch. if you look in the instructions for your header unit (the unict where you insert CD's or tapes etc) this should explain whewre exactly to connect this cable. or you can connect it to the terminal on the ignition switch which becomes live only when you turn the key, should be the third one in. this line basicly tells your amp to turn itself on when it recieves a 12v current. you can also wire it up to a manual switch directly from the battery by connecting another cable to the posative terminal of the battery then to a switch then to the RMT terminal of the amp.
    Dec 27, 2008 | Scosche Industries EFX Amplifier Wiring...
    Car system
    if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
    Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
    Sony XM-2150GSX Car Audio Amplifier Logo
    357 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Larry Stiles
    Larry Stiles
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
