Question about Building Materials
Garage door starts to go up and then reverses?
  • 29 Answers
This could be your problem.
Hope it resolves it.
https://youtu.be/NxBeX-B5usA
Posted on Oct 22, 2017
When garage door is opening the safety sensors activate and starts closesing the garage door. They should activate when I close the garage door.How can I correct this action?
How do you know it is the sensors? Has this opener ever worked properly? Do the main lights flash 10 times when the door reverses? If the opener worked before have you had it apart or done some work to it?
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster garage door opener will not stay closed. It will start down and about half way it will stop and reverse itself. At times it will work properly. When the bounce happpens the light...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors.
Oct 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door starts and stops. I have: Adjusted down force controls still starts reverses then stops checked door sensors OK checked motor OK
If the main light flashes 10 times when the opener reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flashing. Check the small LED on the back of the opener. If it is flashing 5 times and pausing and then repeating you most likely have a bad RPM sensor board which is a small printed circuit board near the front of the motor.
Dec 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Sears Craftman garage door opener closes about 1/3,stops,and reverses.When I activate the remote again it stops rising,starts down again, comes down another foot or so,stops,reverses etc.,etc,etc It...
If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage door opener model # 41a3493-1. Does it have auto reverse?
That isn't the model number you give it is the part number for the logic board. The model number is on the opposite end of the motor unit and starts with 139. If you are asking if the opener should reverse when it hits an obstacle the answer is yes. If it doesn't it is not adjusted correctly or is faulty.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with Garage Door - Stopping and Starting
If the main light is flashing 10 times when the door reverses it is a sensor problem. Make sure the small light on each sensor is lit and not flashing ever so slightly. The sensors must be pointed at one another for both lights to be on.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door opener
You probably have a broken spring on the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
455 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
