Question about Refrigerators
Whirlpool ED22RFXFH01 side by side compressor stopped working, overload switch keeps resetting. Any help?
  • 77 Answers
Pull over load switch and replac it is only a bi metal peace in the switch and wears out replace//////////////////
Posted on Jul 29, 2009
Compressor stops working is there any reset button
no reset button. could be defrost timer, main board or compressor overload. probably best to call for service
Jan 08, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Apr 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool (ER6AHKYPQoo) refrigerator temperature is hot, motor comes on and off then just stops completely. the freezer keeps cool but doesn't freeze.
the rtc contactor overload on the compressor body is not holding in anymore and is short cycling the compressor you will need to access the compressor in the rear of the unit,remove the spring clip that holds the overload rtc and run capacitor on the compressor body,then unplug this from the compressor side body and replace it,then reverse the procedure
Jan 07, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
It appears that the overload keeps tripping on the compressor
Almost certainly the compressor sounds to be faulty. That alarm is possibly the warning that the temp. is not correst. I would switch the system off for approx. 1 hour then retry. if it starts to clck again then it proves the compressor is faulty.
Sep 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD5SHA XLTO2 problems. Last night, awoke to a sort of burnt plastic smell coming from refrigerator. Turned off ice maker and smell stopped coming out. Today, freezer was not keeping things...
sounds as if your overload relay, controlling your compressor has burnt out heres a part number that should getyou back in working order( complete with intructions pn# 8201786
Jun 15, 2009 | Whirlpool GD5SHAX Side by Side...
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Stopped working
no but check the relay on the compressor during a t storm and the ref trying to start it can take out the overload relay combo
May 27, 2008 | Whirlpool ED0GTQXMQ Side by Side...
My Whirlpool Fridg. Model ED22RF has a problem. The freezer is defrosting and neither side is cold. Sounds like the compressor switch is kicking on for a second and then off but the compressor never really...
yea that sounds like a compressor issue( under 5 year manufactrue warr.) you can try replacing te overload/relay assy mounted to the side of thecompressor , sometimes you get lucky and it works part number 4387767
Mar 26, 2008 | Refrigerators
Compressor on whirlpool side by side
STOP! DO NOT RUN UNTIL YOU GET PROPER PART!
I hope you have not ruined the compressor by now. Your original problem was that your compressor start relay assembly was bad. The click noise you were hearing was the overload protector preventing damage to the compressor. When you bypassed this relay and overload protector you may have burned the windings of your compressor. You would need a compressor tester or you will need to put a good relay overload assembly on to see if the compressor is usable now. If the compressor is destroyed the repair bill could run from about $350.00 to $700.00 depending on model and technicians labor charge.
I hope I have helped, supertechks
Mar 06, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
