Question about Dryers
Wont start sometimes burns clothes nosiy
Wont start sometimes belt may be worn out or the start switch is slow
  • 82 Answers
Check the capacitor on the moter if thedrum does not turn this can be the problem
Posted on Jul 29, 2009
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
It washes one way and the clothes get all bound up around agetator..
Probably transmission problem. Spinning and agitating at same time.
Sep 26, 2017 | Washing Machines
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
MY DRYER VIBRATES VERY BADLY, THE CLOTHES STILL SPIN BUT THE WHOLE UNIT MOVES ALOT AND AFTER A FEW MINUTS IT STARTS TO SMELL LIKE SOMETHING IS BURNING.
This sounds like the rubbing strips at the front of the dryer are badly worn and/or the rear bearing is worn. From your description - the drum is sticking - causing the motor to slip on the belt - causing the burning smell.
Replace worn parts including the drive belt.
Aug 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Jeep wont start replaced battery.. sometimes it would start in neutral..its automatic..??last few times i started it, it was very slow to start
Check your charging system to make sure it's working (belt tension, good connections and testing to make sure the alternator and regulator are working)
second, If the starter turns the engine slowly and all electrical is good, likely the brushes inside the starter are worn. If the armature isn't burned and the commutator isn't worn out you can either replace them or change the starter.
Likely if you need to start in neutral the neutral safety switch is worn out. You need instructions from either haynes or chilton to remove it without breaking it. New is over $200 so you may want to consider using a scrapyard part there. Use lots of wd40 and patience when removing as they often don';t come off easily. (location is on passenger side of trans)
Aug 07, 2010 | 1995 Jeep Cherokee
Slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Sep 02, 2009 | Admiral AW22 Top Load Washer
My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 09, 2009 | Avanti 10 lb. Portable Top Load Clothes...
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 19, 2009 | GE WDSR2080D Top Load Washer
My washer wont agitate ?
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Feb 07, 2009 | Maytag Performa PAV2200
Car spudered and die know it won't start
1 Inspect Battery Damaged or faulty battery and/or connections. 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. 3 Inspect Fuel Filter Clogged or dirty fuel filter 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. 15 Inspect Distributor Cap Loose or cracked distributor cap 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). 22 Inspect Timing Belt Slipped or broken timing belt. 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. 25 Inspect Ignition Timing Incorrectly adjusted engine timing.
Dec 08, 2008 | 1995 Buick Park Avenue
Dryers Logo
Top Dryers Experts
