Question about Nintendo Wii Console
Wii shuts down
My wii shuts down completely when I try to turn it on. The red light on the power button turns on when I try to reconnect everything, but when I push power the light turns green briefly and the disc slot lights up blue then it immediately shuts down. After this happens the wii appears to have no power and doesn't respond when i push the power button.
  • 6,784 Answers
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Posted on Jul 28, 2009
Is there a master reset on the wii
Instructions
    • 1
      Locate the "reset" button on the front of the Wii console. Hold it down for a few seconds to reset the device.
    • 2
      Wait for the home screen to appear, then hold down the "power" button on the front of the Wii until the power light turns red and the Wii shuts down.
    • 3
      Unplug the Wii's power supply from the wall outlet or power strip.
    • 4
      Leave the Wii console unplugged for at least five minutes. Reconnect the power supply and press the power button to turn the Wii back on and complete the hard reset.
Nov 06, 2011 | Nintendo Wii Console
Cant get pass the "press A button" screen
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Sep 05, 2008 | Nintendo Wii Console
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
I put new batteries in, all four light flash four times and then it shuts down.I pushed the little red button next to the batteries and all four lights flash fout times and then shut down. Can this be...
What shuts down? The Wii Remote?
If so, sounds like they need to be synced to the Wii. When the controller looks for a connection and doesn't find it, they will shut down to save battery life.
You need to turn on the Wii with the Wii Remote [press power button on the Wii remote that is working] then click into the Wii Menu by clicking the HOME button on the Wii remote. You will then click to Wii Remote Settings. From there, click RECONNECT on the Connection menu. That will instruct you to press 1 & 2 on each remote to sync them.
For more information, click to the following NINTENDO website which tells you everything you need to know that you've asked:
http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp
May 15, 2010 | Nintendo Wii Console
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
My wii will not turn on
try syncing the wii and the remotes. there is a small red button on the wii covered by a small door. and as for the wii remote, there is a small red button where the batteries are located. hold them down for at least 10 seconds i would say and then try turning it on. good luck.
Aug 27, 2009 | Nintendo Wii Console
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Reconnecting
When you turned off the Wii, did the light turn red or amber?
If you haven't done this already, hold the power button until it shuts off, and the light is red. Power it back up and try your remote again.
Jan 25, 2008 | Nintendo Wii Console
Will not turn on from time to time.
can you brow row a friends power supply and try that one see if it still happens
Jan 07, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
321 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
