Question about Intex Pool & Spa
My intex hot tub has a leak int he seam on the inside, how do I fix it
    New Friend:
    Problem Solver:
  • 17 Answers
I would check out flextape.
https://www.neweasy.com/product/flex-tape/?ref=astvdb
Posted on Nov 01, 2017
3 Suggested Answers
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
WHERE IS THE LOCATION OF HEATING ELEMENT ON INTEX SPA HOT TUB
When you take apart the unit its above and between the pump and air pump and like the pump not really serviceable intex no replacement parts
Jun 05, 2018 | Intex Pool & Spa
My intex purespa hot tub model# SJB-HS-10 is flashing E96. I called intex, and they would not even help me trouble shoot it. I was told to buy the whole new control.
Answer
E96 means the PureSpa is experiencing a system error. If the control panel displays this error, turn off the system and unplug it. Plug the unit back in and restart it. If the error persists, turn it off and unplug it. After unplugging it, unscrew the B and C connection until water starts to leak out. Do not unscrew them to the point that they come off of the tub as you can lose all the water in the tub. Loosening them until the leak will release any air from the control base. Tighten the connections and restart the unit. If problem persists, please contact the Intex Service Center for assistance.
Dec 04, 2017 | Lands Phones
I have just installed my intex portable hot tub but there seems to be a leak coming from the bottom.
That's unfortunate. Well, empty the hot tub, and then check the place thoroughly. Is it leaking from inside the outlet? Than check the plug in the outlet tube, if it fits correctly.
Detecting Leak in an Blow Up Hot Tub
Apr 01, 2017 | Pool & Spa
My inflatable therapure jacuzzi tub has a leak on a seam. How do I fix it?
Seam leaks are most difficult to fix on amy inflatable product. However, if yo can find an AC man or an AC supply store that will sell to you they have a tape that is foil on one side and a thick gummy material on the other once in place it is impossible to remove. My brother called it "Hard Cast" but it is not, hard cast is a two part process that will not work for you. This tape has a paper that you must peal off before you apply it.
31644dba-35b4-49c2-9610-b86152d92ddc.jpeg Drain the tub, let it dry, no moisture or dirt or soap residue. Let all the air out of the tub. Then apply enough tape to cover the tare by 2" on all sides. Also trip the tape so that there are no sharp edges. This will not only feel more comfortable but make it harder to peal away. Make sure the tape goes on smoothly and with no wrinkles in the vinyl or the tape. You will only get one shot at this.
May 24, 2014 | Therapure Four Person Inflatable Round Hot...
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Pool & Spa Logo
487 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
