Question about Maytag MSD2756G Side by Side Refrigerator
Maytag freezer don't freeze food or make ice
I have an electric Maytag Side-by-side and it is cold but it does not freeze the items in my freezer and will not freezeice cubes, also my refrigierator is not as cold as it should be.
    Scholar:
  • 117 Answers
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Posted on Jul 29, 2009
Maytag msd2655 freeze work good,fresh food side not cold
HI TRY DEFROSTING ALL FIRST.MIGHT HAVE ICE BUILD UP AT THE BOTTOM.IF IT WORKS GREAT. IF NOT THEN FURTHER INVESTIGATION REQUIRED.SERVICE COND/UNIT.GOOD LUCK ALI
Jul 12, 2012 | Maytag MSD2656G Side by Side Refrigerator
I got two problems with my Maytag Plus side by side with thru diir ice and water. First one is for a few months now it has been creating a large puddle of water that is coming out from underneath of...
This sounds like a problem I had a while back. The drain line was clogged and ice formed restricting the air flow inside. This also resulted in the water leak. The drain hose is located below the refrigerator, above the catch pan. I used a chennile craft stick, which resembles a long pipe cleaner, to clean out the line. There appears to have been mold buildup in the line. I hope this helps.
Sep 16, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Freezer not freezing
if there is ice on the back pannel then your defrost element has gone bad. look at the back of the freezer and see if you see ice on back wall then that will be the problem all so check speed of evap. fan if rotating to slow this will cause a problem also in freezer....
Jul 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Maytag side by side freezer works, fridge does not
the heat is from the condensor keeping the door from frezzing shut it is normal but you need to adjust the food compartment contorl it might say for a for a coler frezzor turn up then you do and the food compartment gets warmer all it is is a air baffle to alow more cold air into the food compartment turn the cold control half way its the one that has off on it and then turn the other control to a lower number to make more cold go into the food compartment
Aug 29, 2007 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
358 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
