Question about Whirlpool Duet GHW9150P Front Load Washer
F02 code flashes and stops rinse cycle - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 1,527 Answers
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Posted on Jul 29, 2009
  • Jessica Swenson
    Jessica Swenson Nov 27, 2012
    Pressing the PAUSE?CANCEL button twice does nothing for me. The door is still locked and I just unplugged it. Any solutions?
jsrock516
  • 5911 Answers
SOURCE: Front loader washer f02 code
If you have already cleared the drain pump reservoir and verified the drain hoses are all clear, you may have a drain pump that is damaged and is not pumping any longer. The following link explains the "F02" error, just in case you didn't know:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The link recommends replacing the drain pump as corrective action if all the preliminary checks prove unsuccessful. Since you mentioned you found quarters inside the pump, its a good possiblity the pump impeller and/or motor has been damaged and is no longer pumping. This next link explains how to replace the pump:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
You can perform this repair yourself, if you wish to save yourself another service call. If this was a Sears service call, their repairs used to be guaranteed for 90 days. Which means, if the repairman fixed the machine and it breaks again within the 90 day period, the next service call should be free of charge. If you do not have such a guarantee and wish to repair this yourself, a replacement pump can be found at searspartsdirect.com. Just type in your model number and follow the parts listings on the next page. For comparative shopping, repairclinic.com also carries the part, sometimes for less. I hope this helps you. If you require addtional assistance, please let me know.
Posted on Aug 17, 2008
JULIANFIX
  • 975 Answers
SOURCE: Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
Posted on May 18, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
  • 10 Answers
SOURCE: Kenmore Elite HE3T model 110 44932 200
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Posted on Jul 23, 2010
SOURCE: I have a Premium WD602
Have you cleaned the filter ? it is located at the bottom, right hand side at the front. You can't see it unless you remove the plynth. It simply unscrews so you can clean it.
Mine was also showing F02 and wouldn't complete the cycle. After cleaning the filter it was fine.
Posted on Oct 10, 2010
Does not rinse
see the cause and fix it. God bless you
Potential Causes
Sep 22, 2012 | Whirlpool GHW9150 Duet Washer
It doesn't finish the cycle and stops and flashes F02
Possible that the drain cycle is not active and so the program trips off. Check the drain for clogging , check the power to the drain from the controller during the cycle, if there is no power the program controller is faulty.
Jul 02, 2012 | Baumatic BTWM4 Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Got code F02 after cleaning all drain system and replacing pump.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%
Jun 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
He3t washing machine
F02 is a drain problem. I took the back off the washer and cleaned out the drainage hose and I guess its a holding tank before it goes out. Both were very clogged with STUFF cleaned it all out now it works better than ever.
Feb 03, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
848 people viewed this question
Dan Webster
Dan Webster
Sal De
