Question about Maytag Portable Air Conditioner M6P09S2A
I also have a Maytag portable ac #M6P09s2a that is leaking water
I tipped the unit a little to drain water fromt the drainplug and water poured out of the back of the unit. Is it safe to remove the back panel and how would I clear out the blockage back there,Help! Its 105 degrees in Portland OR today
2 Suggested Answers
SOURCE: Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Posted on Jul 20, 2011
Old Maytag portable AC leaking. an hwar water when I move , don't know how or where to drain
Make sure the drain line is not stopped up and that the drain pan is empty. The pan relay on the heat from code see to evaporate water and with a full pan that isn't going to happen. Drain line or pan full.
Jun 05, 2016 | Maytag Heating & Cooling
Whers does water evacuate from portable ac unit
there is a holding tank in the bottom of the unit, on the front right by the floor is a rubber cap that plugs this tank. water evaporates from there, if the tank gets too full, the power button will flash red and the unit will not turn on. put pan under, pull plug and drain if this happens. if it doesnt happen, don't worry about exhausting the water as its not a problem.
Jun 10, 2014 | Maytag Portable Air Conditioner M6P09S2A
How do I drain the water from unit before storing
Drain from valve at the bottom of the back of the unit. Look at page 6 of the instruction manual here: http://usermanualnmpeb08f2a.yolasite.com
Aug 25, 2012 | Maytag Portable Air Conditioner M6P09S2A
My son gave me the portable Maytag ac unit. I hav eit operating now and have it resting on the lid ofa rubber made container. So far I have suctioned off 3 large bowls of water. I can`t find how to a
There should be 2 ports in the back or on the side with screw on caps take those caps off and you should see some rubber stoppers when you remove them all of the water will drain out. From what you are saying there should be alot to drain out so be prepared for it to pour out.
Jul 28, 2012 | Maytag Portable Air Conditioner M6P09S2A
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Jun 29, 2009 | Maytag NMPEB08F2A Air Conditioner
Leaking in the maytag m6p09s2a*b
Do you have the Manual to read the trouble shooting page?
How old is the unit?
If not here is a web site to acquire the manual
http://homeappliance.manualsonline.com/ex/thread/view/idThread/326907
Bless you ngafm Waiting for you answer!
Aug 21, 2008 | Maytag Portable Air Conditioner M6P09S2A
Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Jun 13, 2007 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
85 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
