Question about Sewing Machines
Does anyone have information on parts for a Kenmore 158.1789280, I need the motor pulley and timing belt, unit is now "obsolete" and Sears cannot supply parts.... Thanks for your time
  • 670 Answers
I need a parts manual for a Kenmore sewing machine. Model 158.18141
search for:
Make Model parts diagram
Sears will be able to help you.
per Sears:
Call us
We are updating our model/part online database - Additional parts are available through the Sears PartsDirect call center:
If your model was purchased in and you are located in the United States,please call 1 (800) 506-3665.
Jul 31, 2017 | Kenmore Sewing Machines
I have a Kenmore 158-3500 sewing machine and cannot get the side plate off near the hand wheel I have removed the clutch wheel but the hand wheel and belt seem to keep the plate from coming off.
The machine has two belts, one from the motor to a transfer pulley and the second from that pulley to the handwheel. You have to loosen the motor mount (one large screw/bolt) to release tension on the transfer pulley which in turn releases tension on the handweel belt. You will have to take the belts off the transfer pulley to slide the handwheel off (assuming you have already removed knob in the center of the handwheel)
Don't forget to lubricate the shaft of the transfer pulley while you have the end cover off. If this runs dry you will have a problem.
Good luck
Bob
Jan 22, 2017 | Kenmore Sewing Machines
Looking for a users manual for a Sears Kenmore sewing machine model 158.120, not a parts manual.
I would first try Google and ask for service manual for your model. A close model match may do the trick as usually very little variation in same model series. Also, if you locate a Sears service center nearby, they may be able to help you find or instruct you in what you need . Good hunting
Jan 03, 2017 | Kenmore Sewing Machines
I can't seem to find a free manual for my Kenmore 385 17926090 sewing machine. does anyone know where i can download one please? thank you in advance
Sears carries Kenmore manuals, but they are not free. Although, probably a worthwhile purchase considering the information you would have access to.
Sep 06, 2016 | Kenmore Sewing Machines
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
How do I change the motor drive belt on a Bernina 1030?
Adjustment: The stepped pulley support/frame has two 5mm fixing screws on the lower end of the frame and a plastic screw on the upper frame end. Early models had a third screw on the upper side of the frame. By loosening the screws slightly, push the stepped pulley and frame frame toward the loosened side and then let go,...tighten the screws. The frame tension spring is generally sufficient to adjust the belt tension. However, you may want to add a little tension but do not load too tight as you can cause stress on the motor or damage the front motor shaft bearing.
If a belt is needed, you can find them from local companies dealing in bearings, pulleys and drive components, i.e. Kaman Industrial etc. If memory serves me correctly the belt type is MXL, 250mm length, 5mm wide. The outer side of the belt has information to tell you the type. If you want to find one online go to www.sdp-si.com.
http://www.sewtechnical.com/
Apr 05, 2015 | Bernina Sewing Machines
NEED KENMORE SEWING MACHINE MOTOR MODEL 1120
Call your local sears parts department and order the part.
murf427
Aug 02, 2012 | Sewing Machines
I registered our new Kenmore humidifier online using the site mentioned on the yellow registration card that came in the box. The site was not run by Sears. Two months later, the humidifier broke. Sears is...
I used to work at the Harrisburg, PA Sears Parts & Repair center!! The most you can do, is take it back to the store and talk to the store manager. If they care enough about a customer, they will replace it for you!
Feb 23, 2010 | Kenmore 15408
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
