Question about Sport & Outdoor - Others
Tranny sound when at low speed and letting off trottle or just getting back on trottle it sounds like a grinding noise or sounds like tranny isnt all the way in gear other than the sound everything is workin properly
    Novelist:
  • 135 Answers
Try reproducing the sound with the car off to see if it's related to the throttle or engine.
Don't overlook a broken motor mount. If the vehicle is an automatic transmission, you can set the parking brake and with the hood open rock the trans from reverse to forward and see if the motor moves up and down much. Some times a small amount of accelleration while in gear will help to see it move. If it moves up and down, look for a broken motor mount. Try recreating the noise with the trans in park or neutral. This will help to isolate engine or tranny noise. If that's not the problem, someone else will have to help with internal issues.
Posted on Jul 28, 2009
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Mar 19, 2015 | DAF 44 Cars & Trucks
I have a 99 335 sportman. It seems to vibrate in
There might be some worn parts in the differential. If you have a limited slip differential the clutches will make that noise.
Oct 09, 2014 | Cars & Trucks
Low speed noise
Check that the nuts under the back cover at the sides have a bit of nip on them. It could be the armature polling on the fields. DO NOT OVER TIGHTEN THOSE NUTS.
Dec 15, 2013 | KitchenAid K5SS Heavy Duty Commercial...
I have a 92 2 wheel drive Toyota pick up 5 speed transmission 2.4 liter engine. When I let up on the gas while in gear there is clicking/rattling noise in all gears except 4th gear. If I push down on the...
Sounds like you have a defectine cluthch componant. Best way to verify is get the rear axle off the ground . So as not to let the rear drive wheels make contact with the ground. Have an assistant start the truck and put it in gear. After making sure the vehicle is secure crawl under the vehicle and listen to comfirm that the noise is coming from the clutch area.
Mar 25, 2010 | 1992 Toyota Pickup
Front passenger side wheel makes a grinding noise when driving at low speeds. sound gets quieter as I speed up. when I take foot off gas, sound gets louder. braking dont seem to make any difference
sounds like a wheel bearing is going out. you need to get this checked out pretty soon because this can cause more severe problems down the road
Nov 11, 2009 | 1997 Buick LeSabre
Tranny noise coming to a stop
sounds more like the brakes than anything else. it sounds like youre down to metal on metal where you dont have a brake pad left on that side of the car ...have it checked but i dont think it will be the transmission
Feb 28, 2009 | 1995 Ford Windstar
Rattling Coming from Engine At low RPM (stopped) and when accl.
If this sounds like a tin can rattle it is likely a loose heat shield on top of the catalytic converter. They come loose after time and corrosion take their toll.
Feb 25, 2009 | 2001 Lexus Gs 300
I have 91 ford f350 making nosies need help plz help me out
it sounds like the filter might not be the right one....
or the pump isnt priming.....
like "diesel mudder" said previously : was yr tranny in bad shape b4 you changed the fluid and screen?
Feb 25, 2009 | 1991 Ford F350
Sport & Outdoor - Others Logo
67 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
