Question about Xerox WorkCentre 4150/X Laser Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
Xerox WorkCentre 4150, document feeder scans documents, but leaves 3 vertical lines through any document copied, faxed or emailed. Printing from a computer and copying from the glass 1 page at a time work fine. Can't find anything blocking the scan where the 3 blank lines appear. Anyone seen this before?
  • matt882 Jul 29, 2009
    Thanks, but there is nothing on the thin scanner bar at the left of the machine (with the lid open) I wiped it down to be sure, but it's not a smudge, but as if something 2cm wide is completely blocking the scan in 3 locations. It will probably entail taking the scanner apart to see if anything has fallen apart inside the machine.
  • 446 Answers
The problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I get lines when using the auto feeder.
Only clean the **** glass through which passes the document, there must be a pointthat by passing the paper becomes a line
Apr 30, 2012 | Xerox WorkCentre 3220 All-In-One Laser...
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
My workcentre 4150 is on my network and sometimes
Check and see if your using the PS driver for that machine, If so switch to the PCL driver. The PS one has been known to run slow.
Mar 22, 2010 | Xerox WorkCentre 4150/C All-In-One Laser...
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Dec 17, 2009 | Xerox WorkCentre 4150 Black and White...
Document feeder
Most likely there is something in the path.
That feeder is easy to service. But first of all I would take a manila folder adn try and push it through the feeder paper path to clear it of any blockage.
Oct 01, 2009 | Xerox WorkCentre M20 Black and White...
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre  4150/X Laser Printer Logo
672 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
