Question about Acer Aspire 5670 Notebook
Same thing i have just about the same problem but it stay on the white screen. it helps to shut of the power strip/ unplug the computer then re-boot If anyone has a perm fix let meh know :D
  • 408 Answers
The white screen could indicate a bad inverter or the screen itself.The screen staying black could mean the video card has gone out.
Posted on Jul 29, 2009
Which part is failed on my iMac with white screen?
Did you read the Apple support page on this problem? they are really good in helping: Troubleshooting My computer won turn on
Nov 25, 2014 | Apple Imac Alum. 20" 2.4ghz Intel Core 2...
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Acer Aspire One D255-2256 will boot and shut down but when shut off screen turns white until I unplug AC Adapter. I can power back up and boots but when shut down as long as AC adapter is plugged in screen...
Graphics chip may have failed. If screen is white there is no information being sent to the screen, but the backlight is working fine. The Graphics chip may not be replaced, but the motherboard replacement is the usual fix for this issue. There may also be a loose cable beneath the case above the keyboard, which connects the screen to the motherboard.
Sep 28, 2013 | Acer Computers & Internet
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
I have a Sylvania Netbook SYNET07526 that will not boot up.
It will be almost impossible to help with such limited information.
You can try the simple thing. Like unplug and plug the battery again. Or when you power it on try to keep on pressing the button F2 to check if it will let you in the BootMenu.
Nov 26, 2017 | Sylvania G-Netbook
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Clicking
unplug the power cord first!!!
then...
if you lift up the cover for the keypad, there will be a little hole under the black switch. press the little button like thing and then slide the whole thing forward. unplug the ribbon strips and undo the screws. then open the lid where you photocopy (top one) and undo the screws on the left. then pull the lid upwards so that it comes of. it will take a bit of strength. there will be a screw there, undo it.
this will enable you to lift the whole thing of so that you can get inside. if you look at the glass screen, you will notice that there is a white strip next to it. mark a little dot on the other side of the plastic where the white strip is. the put the glass back on. mark a dot on the main body where the white strip is. lift he screen of and line the light bar with the mark you have drawn.
put it all back together and start it up. hopefully it should work :)
Jun 13, 2009 | HP PSC 2510 All-In-One InkJet Printer
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
Acer Aspire 5670 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
